A series OHC engine
coldplugs
Platinum
I was sorting through some pictures tonight and thought this might interest Mini folks. It's on display at Gaydon.
In deference to dial-up users I'll post a small version here. Click the link for a larger version of the same shot.
OHC Engine
[ 02-12-2003: Message edited by: coldplugs ]</p>
TypeRboy
Too bad it was only experimental..
MattP
I had heard of this engine before, but without benefit of pictures. I heard of it as being planned for the Midget(the Sprite was gone by'72) but with the impending US smog regs, the development costs were thought too high, and it lost out to the Spit's 1500. Sweet to see it.
Feel free to count the above as hearsay if you have better info. I always get antsy when I can't cite sources. But I think that I read all that somewhere.
MattP
coldplugs
coldplugs
Platinum
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by MattP:
I had heard of this engine before, but without benefit of pictures. I heard of it as being planned for the Midget(the Sprite was gone by'72) but with the impending US smog regs, the development costs were thought too high, and it lost out to the Spit's 1500... <hr></blockquote>
I've read the same thing, although the references I saw were to a twin cam head. I suspect they were wrong about that part. This head looks to me like they were interested in dealing with the emission issues rather than performance and I think this may be the engine that lost out to the Spitfire 1500, as you mentioned.
aeronca65t
Looks like they kept the original cam in place, I guess to drive the oil pump and maybe distributor. Air pump does seem to imply it's designed for emissions.
Too bad really...the 1500 I have in my Spridget is OK, but I think I would have preferred this little "A" lump cammer.
William
They did an OHC version of the B-series lump as well, which would've helped out in the MGB, I would imagine. David Knowles' book "MG" has a pic of the OHC B-series in an MGB. Forget if the engine was actually used elsewhere.
-William
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
O TR6 TR series transmission compatibility Triumph 4
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Healey Nut "Father Brown" British television series Austin Healey 9
Basil Series 1 EType Spotted 2
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
S M Series Bonnet Striker Pin failures TVR 2
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
G original radio 1961 e series jaguar Jaguar 3
Y M Series indicator lens TVR 2
Q Series 1 E Type Clutch Jaguar 2
F 1965 Humber Super Snipe Series Va Other British Cars 5
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
David Townsend T-Series MG Midget TC Series Limited Edition Illustrations MG 1
J TR4/4A TR4 Series Vehicle numbers Triumph 1
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
