Series 1 E Type Clutch
Quelch
Member
Hi Everyone,
I have a 1667 series 1 E Type OTS. I have just purchased a complete 9 1/2" clutch assembly advertised as good for all cars 1964 to 1971. However when I got my gearbox and engine separated I found that the existing clutch was a 10". When I placed the new clutch over the flywheel I noticed that there are another series of fastener holes that do line up with the new assy , however the two spigots would have to be re-located.
Has anyone managed to successfully replace a 10" clutch with a 9 1/2" clutch and what other modifications if any are there to do? Or should I return it and get the proper 10" assy.
Administrator
Boss
I have a 67 E-Type as well. It has been a while since I had the clutch apart, but it sounds like you may have gotten the wrong clutch. Can I ask where you bought the new clutch? If it's one of the main suppliers (Like Terry's or XKS) you should call them and inquire about the difference. If I was replacing my clutch I think I'd want one that didn't require modifications to fit.
Geo Hahn
Sounds like you have the early 10" Laycock clutch which you may find is no longer available. I think a conversion to the 9.5" is the usual solution.
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M E-type series 1 plastic dash vents Jaguar 1
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
D Series III E-Type Overider Rubber Installation Jaguar 2
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
Simmo Series 3 E Type Brake Bleeding Jaguar 2
J Question about Series III XJ6 Motor in E Type? Jaguar 2
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
weewillie Red series 1 or 2 E type Spotted 0
glemon Series 1.5-2 E type, flat towed Spotted 0
glemon Series I E type project Jaguar 17
HEALEYJAG series 2 E-type eyebrow chrome "clips" Jaguar 0
B Series 1 E-Type fuel pump question Jaguar 2
S E-Type 4.2 Series II Performance Exhaust Jaguar 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
rovernut 1970 series 2 e type serial number location Jaguar 6
T Series 2 E-Type Diff Oil Leak... Jaguar 5
Steve Red Series 1&1/2 E-Type.... Spotted 0
Bruce Bowker Series III E Type Jaguar 9
Basil Drool Series I E-Type Jaguar 10
HEALEYJAG series 2 e-type bonnet Jaguar 14
Jim_Newman 4.2 series 1 e-type throwing coolant Jaguar 6
HEALEYJAG e-type series two oil filter Jaguar 6
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
M Looking for a E Type Series III Bell Housing Jaguar 1
S Performance Exhaust for E-Type 4.2 Series II Jaguar 3
C Series II E Type Clock Battery Jaguar 2
Rick60 E-Type Series 3 V12 distributor Jaguar 5
S E-Type Series II OTS Exhaust Jaguar 0
S E-Type Series II OTS Sound System Upgrade Jaguar 0
D Series 2 E-Type won't rev. Jaguar 6
B 69 Series II E-type Hardtop window Jaguar 0
S Bouncing Tach on Series III E-Type Jaguar 4
R Radiator -Series 1 E-Type Jaguar 0
L E-Type Series II vacuum connections Jaguar 0
G Series III E-Type problem to look out for Jaguar 1
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
