Series 2 E-Type Diff Oil Leak...
Platinum
IMO, best way is to do it right once: drop the subframe and do it on the floor. Brakes become VERY easy to get to as well. :wink:
T
TRDejaVu
Thanks Doc.
How difficult a job to:
- drop and refit subframe
- change diff seals
- R&R brake calipers
What else would you do while the subframe is down?
jessebogan
Common causes: Diff side seals, and Pinion seal. Like Doc sez, drop the entire cage, rebuild the rear calipers, replace pads, both main and hand brake, replace the rotors if needed, and replace all the seals. Fairly low degree of difficulty, and if you do it all at once, you can forget about it for years.
Platinum
...and if ya DON'T do it all once you'll become well-and-truly <span style="font-style: italic">proficient</span> at droppin' that subframe! :wink:
Grantura_MKI
Built yourself a plate that will lock in to your floor jack. Weld a stud on top of the plate that will screw into the diff drain plug. Fit plate to diff, jack up the jack, lock in the plate...drop the hole cage and pull out.
I do not like bleeding the calipers though...shyte job that!
Be sure to put sealant on the inside of the flanges before fitting the washers and nuts.
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M E-type series 1 plastic dash vents Jaguar 1
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
Q Series 1 E Type Clutch Jaguar 2
D Series III E-Type Overider Rubber Installation Jaguar 2
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
Simmo Series 3 E Type Brake Bleeding Jaguar 2
J Question about Series III XJ6 Motor in E Type? Jaguar 2
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
weewillie Red series 1 or 2 E type Spotted 0
glemon Series 1.5-2 E type, flat towed Spotted 0
glemon Series I E type project Jaguar 17
HEALEYJAG series 2 E-type eyebrow chrome "clips" Jaguar 0
B Series 1 E-Type fuel pump question Jaguar 2
S E-Type 4.2 Series II Performance Exhaust Jaguar 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
rovernut 1970 series 2 e type serial number location Jaguar 6
Steve Red Series 1&1/2 E-Type.... Spotted 0
Bruce Bowker Series III E Type Jaguar 9
Basil Drool Series I E-Type Jaguar 10
HEALEYJAG series 2 e-type bonnet Jaguar 14
Jim_Newman 4.2 series 1 e-type throwing coolant Jaguar 6
HEALEYJAG e-type series two oil filter Jaguar 6
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
M Looking for a E Type Series III Bell Housing Jaguar 1
S Performance Exhaust for E-Type 4.2 Series II Jaguar 3
C Series II E Type Clock Battery Jaguar 2
Rick60 E-Type Series 3 V12 distributor Jaguar 5
S E-Type Series II OTS Exhaust Jaguar 0
S E-Type Series II OTS Sound System Upgrade Jaguar 0
D Series 2 E-Type won't rev. Jaguar 6
B 69 Series II E-type Hardtop window Jaguar 0
S Bouncing Tach on Series III E-Type Jaguar 4
R Radiator -Series 1 E-Type Jaguar 0
L E-Type Series II vacuum connections Jaguar 0
G Series III E-Type problem to look out for Jaguar 1
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
