Bouncing Tach on Series III E-Type
sammyb
My father-in-law just called after picking up his new Series III E-Type Coupe. He said the tach is bouncing wildly, and asked me if it's electrical, mechanical or what -- to which I said "it's mechanical on some british cars, electrical on later ones, but I don't know on the '73 without looking."
I would suspect it's electrical and he has a faulty voltage regulator. He'll be here in an hour.
Anyone know off hand and suggest a cure?
Bruce Bowker
I am fairly sure it is electrical with possibly a "generator" running of one of the cams. See if you can trace a wire.
Bruce
S
sammyb
My in-laws came over with the car, and the tach is really bouncing wildly -from pin-to-pin. The clock doesn't work and the oil pressure gauge was just disconnected by the Jag dealer that had the car, because it was bouncing wildly.
I'd guess voltage regulator -- told my in-laws to order a new one from Moss.
It's a pretty fun car. Great engine note. Very narrow and feels small, but very heavy. I wouldn't want to rush it around a track!
John S Farrington
The tachometer is electrical and uses the ignition to drive the instrument. It sounds like you have a defective tachometer but the other instrument problems conflict from that. I dont believe that the alternator voltage regulator could cause such a problem. The Jags use a voltage stabilizer for the dash instruments; this could be the source of the problem.
S
sammyb
This is why I like my TR3 -- there are two fuses and one regulator for the whole dang car. Pretty easy to track problems. (Plus only four spark plugs to change!)
V TR2/3/3A Bouncing Tach on TR-3B Triumph 4
D Bouncing Tach Needle Spridgets 2
KVH General Tech Speedometer Pointer Bouncing Around Triumph 22
I TR6 75 TR6 Speedometer bouncing Triumph 7
K TR2/3/3A The TR3 Bouncing Ammeter Gauge? Triumph 6
Got_All_4 Bouncing Betty Speedometer Needle Triumph 7
S Spare Tire Bouncing Around Spridgets 2
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ā€˜74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
