tach goes crazy
rjc157
Just got my tach back from nisonger for the second time and it reads way off and when driving just goes crazy they feel its a bad ground somewhere ,where do I start and what do I do its a neg ground car with a alt conversion ,could the coil have gone bad any help appreciated
Patrick67BJ8
"they feel it's a bad ground somewhere"...I'd check behind the tach and make sure there's a black ground wire securely attached to the tach bracket. Also take an ohmeter and read the tach case to a known good ground for continuity.
Healey Nut
Run a temporary wire from the back of the tach direct to the main ground either on the battery itself or where the battery is grounded and try it . If that solves it you have a ground problem .
RAC68
Hi Ralph,
Is there anyone close by that has a negative ground Healey and will be willing to connect and test your tachometer. This would verify whether the tach is performing and the cause is in your electricals. If it turns out to be in your connections, how many loops are in your white ignition wire. Last, and this is a question that just needs mentioning, are you sure the returned tachometer contains the negative ground modifications I assumed you installed before sending?
Although I agree with the Healey Nut's alternate ground suggestion, the ground to the tachometer is shared across all the gauges and, if it were not present, I would expect your panel lights would not work.
Good luck,
Ray (64BJ8P1)
rjc157
rjc157
Everything works this is the second time I got it back I went to the shop and they showed me that the needle is spot on but when put in the car its off it reads high in idle put a external meter on the coil to read the rpms and it shows about 300 rpms off will put a direct ground wire going to the battery and see what happens
rjc157
rjc157
just ran a ground from the tach to the battery and still the same thing ,when I detached the ground wire from the back of the tach nothing different happened shouldn't the needle drop to zero if there is no ground
Healey Nut
The only thing I can think of is that the coil is going bad and maybe the condenser
Try a new condenser set the points , check the dwell angle and try that . Condensers are cheap .
pkmh
Replacing condenser and or coil sounds good for I had my tach dancing between 3000 to 4000rpm until I replaced those two items (among other things like dealing with the distributor cap and wires, etc.), but I never made that connection or conclusion when the tach's dancing stopped on mine.
AngliaGT What Goes to the Left of the Tach? Spridgets 3
B MGB MGB Cuts out, Tach goes dead..... MG 18
Tim_80B Positive wire for Tach goes...where? MG 2
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ‘74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
Sopwith_Camel tach-less Spridgets 11
B Lazy Tach Austin Healey 2
J Tach drive housing eccentric Austin Healey 14
G MGB Tach and speedo rebuild. MG 3
Schroeders T-Series TF Tach Calibration - DIY? MG 3
Darwin Spitfire Help wiring up a tach Triumph 9
