MGA Tach drive issue
Bob Branson
Member
I hope someone has already solved this so I don't have to reinvent the wheel: Tach doesn't work, but the instrument and cable are good (works when clamped into an electric drill.) Cable end is square, collar tightens easily by hand, and drive rotates while engine is running. But on close inspection, it appears the drive's square hole may be a bit wallowed out. I've considered fashioning some sort of sleeve for the cable end, perhaps heat shrink tubing. Has anyone ever dealt with this exact issue, and what did you do, short of spending &149 for a new drive?
JPSmit
On my Midget I had this with the speedometer. Went to a hobby store and bought a piece of square brass stock. IIRC it took a couple of tries but made it fit and Bob's your uncle
Lin Tach drive housing for BT7 Austin Healey 4
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
5 Tach Drive Generator for a Bugeye Spridgets 2
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
J Tach drive housing eccentric Austin Healey 14
5 Tach Drive on Bugeye Austin Healey 10
D Tach drive died Spridgets 11
I tach drive repair Spridgets 7
I tach drive questions Spridgets 3
TulsaFred Bugeye tach drive generator Spridgets 2
PAUL161 MGB MGB Cable Tach Drive? MG 5
HealeyDave Tach Drive Refurb Austin Healey 2
eschneider TR2/3/3A TR3 distributor tach drive disassembly Triumph 7
PatGalvin Distributor Pedestal Tach Drive Triumph 2
M Distributor tach drive seal replacement ???? Triumph 2
livinginthepast tach angle drive grease - which one? Spridgets 2
dklawson Tach Drive Generator Spridgets 2
M What Grease For The Generator and Tach drive Spridgets 6
bill_young Alternator with cable tach drive. MG 0
bill_young Alternator with cable tach drive Spridgets 7
6 Tach Drive/Oil Line Connection? Austin Healey 6
B Bugeye + 1275 + Tach Drive Spridgets 13
dklawson Tach Drive Generators? Spridgets 1
Lin Tach Drive Mounting Austin Healey 1
John Moore Tach Drive Generator Spridgets 3
John Moore Tach Drive Generator Spridgets 1
emann Tach Drive Gearbox - oops Spridgets 7
T TR6 TR6 distributor removal - tips on tach drive Cable Triumph 5
B Tach Drive Spridgets 10
drooartz Good drive, and broke the tach Spridgets 5
Bob Claffie Tach drive Austin Healey 2
J E type tach drive Jaguar 4
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ā€˜74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
