Series III E-Type problem to look out for
Gene
Good tip, Wally! I recently had the reverse problem returning from a VJC event in Richmond. I suddenly noticed that my voltmeter was all the way over to the right! Many volts! I would stop and tap on the voltage reg and stop and restart and, for a while, all would be well. Then, without warning, the same thing again.
I had to replace the voltage regulator.
Wally
While returning home from a Brit Car show/gathering in Ventura, CA, on a very hot day, I noticed the battery voltage was below normal and falling! Being about 100 miles from home, I decided to chance it. The I-5 Tejon pass was ahead with a good climb but thought I could make it. The engine cooling fans were rapidly draining the battery. I almost made it. Last few miles were on the back of a AAA hauler. Problem turned out to be the field wire from the voltage regulator to the alternator. This wire runs through the engine right side wiring harness strapped to the frame rail and then emerges to go to the alternator. All those years of the engine squirming around in its mounts relative to the fixed frame rail had fatigued the wire so that it broke at the connection. Other V-12 owners might just want to check this before they too are left on the roadside far from home. Cost of repair: about $0.50 for new spade connector.
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
D Series III E-Type Overider Rubber Installation Jaguar 2
J Question about Series III XJ6 Motor in E Type? Jaguar 2
Bruce Bowker Series III E Type Jaguar 9
M Looking for a E Type Series III Bell Housing Jaguar 1
S Bouncing Tach on Series III E-Type Jaguar 4
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
toysrrus Series III Rdstr. Top Bows [Grey] & Vinyl [Blk] Top For Sale. Jaguar 4
D XJ6 series III front end rattle Jaguar 5
D Series III side marker to blinker conversion Jaguar 2
M 87 Series III XJ6 Rough Running Jaguar 16
M 87 Series III XJ6 won't Start Jaguar 16
M Series III XJ-6 4.2 Liter Cylinder Head removal Jaguar 7
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
Sprocket Series III factory service manuals - $50 Jaguar 0
M Alternator or Battery Problem on 87 XJ6 Series III Jaguar 5
M Tricks for Alternator Removal 87 XJ6 Series III? Jaguar 8
wkilleffer Series III XJ6 a/c amp questions Jaguar 1
bmurphy7369 Late Series III motor/FI into a Late Series II XJ? Jaguar 5
bmurphy7369 Need some rust repair advice for Series III XJ6 Jaguar 8
S Easiest way to disconnect Tach on XKE Series III Jaguar 4
P Correct steering wheel for Series III Sunbeam (Rootes) 3
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
