Series III XJ6 a/c amp questions
wkilleffer
Hello everyone,
I'm getting a bit fed up with my Jag's a/c. Just about the time the interior gets comfortably cool, the system switches the heat on full blast. It will respond to the temp setting knob, but not for awhile after it's played that trick.
According to the jag-lovers.com site, that's a symptom of a/c amp failure. The a/c amp's an expensive part, though they seem to think that an aftermarket unit can be obtained for around $150US. I've asked about it on their forum, but am impatient enough to ask here as well. Where can I get an inexpensive new or rebuilt aftermarket unit?
Also, there's supposed to be a way to bypass the amp entirely that requires some cutting into the system wiring. I'm not against the idea, but don't want to ruin things either. Since I'm trying to sell the car, it's probably best that everything work as intended.
Another question: I've heard that changing the amp can affect certain a/c functions, such as being able to swich the system from Auto to High or Low and actually have something happen. It used to, but doesn't anymore. The switching the heat on at bad moments hasn't always been a problem either. I've owned the car for about a year-and-a-half, and this has been trouble for about a year.
Any advice or suggestions would be appreciated.
Thank you,
John S Farrington
I would not try to modify the system; that is a very bad idea particularly if your system is partially functional. Either your amplifier or the mechanical servo that it drives is causing this problem. The amp is probably the problem as it sounds like it is breaking down after it warms up. If you can get a rebuilt amp for $150 that is a good buy. They usually cost double that and as the car gets older they are getting harder to find.
J Question about Series III XJ6 Motor in E Type? Jaguar 2
D XJ6 series III front end rattle Jaguar 5
M 87 Series III XJ6 Rough Running Jaguar 16
M 87 Series III XJ6 won't Start Jaguar 16
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
M Alternator or Battery Problem on 87 XJ6 Series III Jaguar 5
M Tricks for Alternator Removal 87 XJ6 Series III? Jaguar 8
bmurphy7369 Need some rust repair advice for Series III XJ6 Jaguar 8
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
D Series III E-Type Overider Rubber Installation Jaguar 2
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
toysrrus Series III Rdstr. Top Bows [Grey] & Vinyl [Blk] Top For Sale. Jaguar 4
D Series III side marker to blinker conversion Jaguar 2
Bruce Bowker Series III E Type Jaguar 9
M Looking for a E Type Series III Bell Housing Jaguar 1
M Series III XJ-6 4.2 Liter Cylinder Head removal Jaguar 7
Sprocket Series III factory service manuals - $50 Jaguar 0
bmurphy7369 Late Series III motor/FI into a Late Series II XJ? Jaguar 5
S Easiest way to disconnect Tach on XKE Series III Jaguar 4
S Bouncing Tach on Series III E-Type Jaguar 4
P Correct steering wheel for Series III Sunbeam (Rootes) 3
G Series III E-Type problem to look out for Jaguar 1
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
