Wanted Spats - XK Series?
nick6063
Hello,
Although I am a Triumph nut, I picked up these spats while purchasing a bundle of triumph parts. I believe they are for the XK series. Am I correct?
What would these be valued at if I would offer them for sale? Thanks, Nick
PhilW
If you look at the inner support edge near the top, you'll see a number stamped there. It's the car number these were made for. Each pair was made for 1 specific car. Looking at the bottom corners, I believe only 1 corner had a pin and the other had a notch for the pin on the fender. It's a common fix, as they fell off the cars rounding hard corners from year one.
Phil.
N
nick6063
Thank you Phil. I will check for the stamped number. This info is vey helpful. Unfortunately the spats are located at my lake cottage, so will check in the spring. Do you think these are for the XK-120 thru 150 series?
Nick
PhilW
Most of the spats are for the 120's,much fewer for the 140, and rare on the 150's. Most XK's came here to the states and everyone wanted wire wheels (no spats used with w/w). My 120 with spats is elsewhere, so in a week or 2 i'll check if mine look like yours. The long rod on yours is incorrect, but then a lot of changes were made over the years by owners to keep the spats from flying off. It's possible your's are not Jag, as other British cars of the time had very similar covers.
Phil.
1 TR3 Fender spats sold on EBay. Triumph 5
K TR2/3/3A TR3 Spats?...Fender Skirts. Triumph 3
T TR2/3/3A Triumph Fender Skirts [Spats]???? Triumph 7
K TR2/3/3A TR3 Fender Skirts or Spats Triumph 28
S TR2/3/3A Full spats for a TR3? Triumph 11
M XK 140 fender skirts [spats] Jaguar 0
martx-5 Need a set of Spats?? Triumph 20
mcguijo TR 3 Fender Spats Triumph 14
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
O TR6 TR series transmission compatibility Triumph 4
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Healey Nut "Father Brown" British television series Austin Healey 9
Basil Series 1 EType Spotted 2
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
S M Series Bonnet Striker Pin failures TVR 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
G original radio 1961 e series jaguar Jaguar 3
Y M Series indicator lens TVR 3
Q Series 1 E Type Clutch Jaguar 2
