Xke series lll cooling issues
Deanrobert
I’ve owned a 74 xke since new.. we have the original radiators / fans etc. we always have to watch the temps in the summer time/ don’t run the a/c when dr icing in town , etc.
My question is , do the aluminum radiators / expansion tank and all that Moss Motors catalogue promote to “fix” our hot running jags really make a difference ? Or do we just live with issue that’s part of owning a jag??
LarryK
If your block is clean of silt and water pump is up to snuff, should be ok. Radiator cleaned may help, with a new thermostat. If hoses are newer that are not so soft they collapse is a plus. Aluminum radiators are usually have an extra row of fins. An electric fan controlled by a thermostat s good too. I have never changed the cooling system in my jags, kept them cleaned and flushed. Check for dragging brakes too.
Deanrobert
Deanrobert
Thanks Larry ; i flushed the system last year., fans are electric thermostat controlled - hoses were replaced years ago: we’ll do it again
LarryK
Maybe warmer weather and traffic could be an issue. Make sure caps are god as these usually run on lower pressure. 15 lbs? I would have to look it up. My MK1s are 7, and my Valiant is 5.
NutmegCT
Flushing. What actually does that mean? Just drain and refill, or draining, then power flushing under pressure to force the crud out?
Tom M.
LarryK
Flushing can blow heater cores.
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
P XKE series 1 FHC windshield installation ?? Jaguar 4
B Looking for some XKE series 2 parts Jaguar 0
HealeyDave '64 XKE Series 1 on Craigs Jaguar 5
J XKE series II S/Z carbs hot start woes Jaguar 1
A XKE Series II Stromberg Carb Upgrade Jaguar 4
H What to look for in a restored Series 1 XKE coupe Jaguar 9
wangdango XKE series 1 lower radiator pipe size? Jaguar 1
T XKE Series 2 Rocker Switch Holder Panel Jaguar 0
T XKE Series 2 Heater Valve Jaguar 0
T XKE Series 2 Floor Covering Jaguar 1
T XKE Series 2 Cooling System Jaguar 0
T XKE Series 2 Radiator Jaguar 8
S XKE 1970 Series II OTS Outside Mirror Jaguar 3
T XKE Series 2 Turn Signal Lever Stalk Wiring Jaguar 5
T XKE Series 2 Starter Relay Jaguar 3
T XKE Series 2 Brake Servo Jaguar 2
T XKE Series 2 Instrument Panel Jaguar 2
wangdango series 1 xke heater Jaguar 2
toysrrus "JAGUAR XKE" Series II Rear Bumper Ass`y For Sale: Jaguar 0
S Easiest way to disconnect Tach on XKE Series III Jaguar 4
bighly WTB early XKE Series 1 Jaguar 3
R XKE series 2 Brake rotors Jaguar 3
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
CJRams For Sale 1969 Jaguar XKE Jaguar Classifieds 0
BritBite XKE BRAKES Jaguar 1
B For Sale 1968 XKE Roadster 1.5, 4.2 Jaguar Classifieds 0
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
M 65 XKE FHC Rea Hatch Door Jaguar 2
M XKE Bonnet Restoration Jaguar 5
C Garage find '65 XKE Jaguar 12
wangdango '67 XKE rear diff? Jaguar 2
wangdango XKE clutch flex line/firewall? Jaguar 1
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
T Need some coaching on is a XKE project Jaguar 6
E Jag xke chassis number 885616 Jaguar 1
F XKE SIII Drivers Door Mirror Knob Jaguar 1
Marvin Gruber Eagle XKE Jaguar 2
T Sourcing a correct engine for a '71 XKE Jaguar 14
AH67 1E120049 1966 Jaguar XKE Roadster Jaguar 1
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
tlthorne anyone with a 69' XKE convertible in pcs??? Jaguar 2
tlthorne Looking for a source for the fasteners for a XKE Jaguar 7
K Problems with Bleeding the Brakes onan XKE? Jaguar 2
aeronca65t XKE racer Jaguar 1
H 1969 Jaguar XKE - Oil Jaguar 7
