XKE series 1 FHC windshield installation ??
pguzman
Good morning ;
I am having a really hard time installing a new windshield in my FHC ( to put it mildly ) !!! Anybody out there have any experience or words of wisdom on getting this done?? I have tried doing it with the seal on the frame, then trying to fit the windshield into the seal (using the rope and nylon windshield probes). Using this method, I was able to get the bottom of the window into the seal, but I couldnt get the upper corners in. I then tried to start by inserting the top of the window first. I was able to get the top in, but couldnt get the bottom corners in. I then talked to a "Jag Expert" who said he put the seal on the window and using a rope, he installed it from the back (pulling the seal onto the frame from the back.) This didnt make a lot of sense to me since the Jag seal without the lock strip is much more flexible toward the front then the back. Using this method, I was able to get the bottom of the window in but was having a hard time getting the seal arong the lower corners. About this time I managed to crack the window's inner pane (not very happy about this time )!!! So now, with my car fund 700 bucks lighter, I am still trying to figure out a way to get this installed without depleting my car fund of another 700 bucks !!! Any words of wisdom will be greatly appreciated !!!
Incidently, I dont usually have any problem installing TR4 windshields. Even the back glass on my surrey top went in without any hardship, and they use less flexible solid seals.
LarryK
Put seal rubber around windshield ( soak in hot soapy water first, five gallon bucket is nice ) then put seal around windshield. Put a small rope around windshield towards back of seal. Get another person, put windshield up to frame and have person hold carefully with slight pressure while you pull on rope from inside. Try not to extend rope over 90 deg and carefully pull, using soapy water spray as you need it. Slow and careful. Practice on cracked one, just be careful and you will get it. Does take 2 people.
LarryK
Any feedback on wether you were able to get windshield installed?
P
pguzman
Good evening LarryK;
Thank you for the advice !! I have not tried to install it yet. Hopefully next week(or two) one of my friends will be coming down to help me put the beast in. He happens to have several of the pump down window suction cups and will bring a couple down with him. I have several of the yellow plastic cups, but it was evident pretty early that they were not strong enough to be of any help. You do (at least in this case) get what you pay for!! We do intend to practice on the cracked window, as you suggested. Do you know why the XKE window is so hard to install?? One of my cohorts thinks that it's because of the extreme curvature at the ends. That doesn't seem likely, since the TR surrey top back light has quite a bit more curve to it and even though it uses a solid seal (no lock strip)it went in a lot easier. I was using your method when I cracked the window, however I wasn't using pump down suction cups, and I didn't soak the seal in hot water, Hopefully that will make a difference. I usually use parachute cord for the rope (about 3/16 thick), is that about what you use ??? Again, I appreciate your advice, thank you very much !! I will let you know how things workout !!!
LarryK
Harder to install because of curves and tighter seal for road speeds to seal from wet.
Deanrobert Xke series lll cooling issues Jaguar 5
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
B Looking for some XKE series 2 parts Jaguar 0
HealeyDave '64 XKE Series 1 on Craigs Jaguar 5
J XKE series II S/Z carbs hot start woes Jaguar 1
A XKE Series II Stromberg Carb Upgrade Jaguar 4
H What to look for in a restored Series 1 XKE coupe Jaguar 9
wangdango XKE series 1 lower radiator pipe size? Jaguar 1
T XKE Series 2 Rocker Switch Holder Panel Jaguar 0
T XKE Series 2 Heater Valve Jaguar 0
T XKE Series 2 Floor Covering Jaguar 1
T XKE Series 2 Cooling System Jaguar 0
T XKE Series 2 Radiator Jaguar 8
S XKE 1970 Series II OTS Outside Mirror Jaguar 3
T XKE Series 2 Turn Signal Lever Stalk Wiring Jaguar 5
T XKE Series 2 Starter Relay Jaguar 3
T XKE Series 2 Brake Servo Jaguar 2
T XKE Series 2 Instrument Panel Jaguar 2
wangdango series 1 xke heater Jaguar 2
toysrrus "JAGUAR XKE" Series II Rear Bumper Ass`y For Sale: Jaguar 0
S Easiest way to disconnect Tach on XKE Series III Jaguar 4
bighly WTB early XKE Series 1 Jaguar 3
R XKE series 2 Brake rotors Jaguar 3
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
CJRams For Sale 1969 Jaguar XKE Jaguar Classifieds 0
BritBite XKE BRAKES Jaguar 1
B For Sale 1968 XKE Roadster 1.5, 4.2 Jaguar Classifieds 0
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
M 65 XKE FHC Rea Hatch Door Jaguar 2
M XKE Bonnet Restoration Jaguar 5
C Garage find '65 XKE Jaguar 12
wangdango '67 XKE rear diff? Jaguar 2
wangdango XKE clutch flex line/firewall? Jaguar 1
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
T Need some coaching on is a XKE project Jaguar 6
E Jag xke chassis number 885616 Jaguar 1
F XKE SIII Drivers Door Mirror Knob Jaguar 1
Marvin Gruber Eagle XKE Jaguar 2
T Sourcing a correct engine for a '71 XKE Jaguar 14
AH67 1E120049 1966 Jaguar XKE Roadster Jaguar 1
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
tlthorne anyone with a 69' XKE convertible in pcs??? Jaguar 2
tlthorne Looking for a source for the fasteners for a XKE Jaguar 7
K Problems with Bleeding the Brakes onan XKE? Jaguar 2
aeronca65t XKE racer Jaguar 1
H 1969 Jaguar XKE - Oil Jaguar 7
