BMC A-series: Oil in coolant
Ladybug
(Non-native speaker, my apologies for any errors)
The 948 cc A-series engine on my Austin a35 (completely rebuilt a couple of years ago) is leaking quite a bit of oil in to the coolant. No sign of leakage occurring the other way tho. I've only been able to find detailed instructions on trouble-shooting and fixing the issue on BMC's C-series engines.
Any advice or links on the matter are greatly appreciated 🚗
Madflyer
Look at it this way higher pressure wins. your coolant pressure is between 9 and 12 pounds from Radiator cap, Right.
Your motor cyl. pressure at near new is over 100 pounds so it is pushing the block pressure to water jacket. Retorque head in the right order twice hot and cold. I would not think crack block but head gasket, there are a few spots where the material is thin between cyl and water jacket that would be the worse case. MF
Pat MM
The 948 is the same engine used in the Morris Minor and the Sprites and Midgets. There is a huge amount of information available online. It is always worth a try retorquing it, but if that doesn’t fix it, you will be removing the head.
Since the engine has been apart in the past, the head studs may need to be replaced and your head needs to be checked to make sure that it is flat.
Good luck getting it repaired.
I really miss my A35 van, but had to sell it and my ‘67 Cooper S to pay for childcare when I was in school. At least I was able to keep the Sprite!
L
Ladybug
Thank you both. I did notice this was a frequent topic on MG forums, but wasn't aware that midget had the same engine.
Madflyer
The above is correct as to head studs a small cost but smart money tighten more than three times that you know of. Only a light dressing of head is needed to make sure it is flat and true. and yes used on many cars. MF Where is Tampere
L
Ladybug
Where is Tampere
Finland :smile:
After retorque and thoroughly rinsing the radiator, there seems to be much less oil. We'll be taking the engine out and reassembling anyway come winter. Might not be worth the effort tho - seems to be more of a feature than a flaw 😁
Madflyer
These motors are built for wear and tare and worth the rebuild. And yes they leak, a good look and inspection and careful reassemble will bee good for many years. This Forum as a guide as a tool also. MF
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
KellyRob BMC GEARBOX 1960 British Motor Corp 2
K BMC Supplemental Tool Kit Bags Austin Healey 14
O For Sale BMC Service Shop sign Other British Classifieds 3
B orginal BMC radio Austin Healey 9
C BMC Special Tuning Data Austin Healey 9
K MGA BMC paint colour code AL1 MG 2
K BMC paint colour code AL1 [wire wheels] Austin Healey 1
HealeyRick The BMC Story Spridgets 7
HealeyRick The BMC Story Austin Healey 29
HealeyRick "Tuning BMC Sports Cars" Spridgets 11
abarth69 Dry Sump BMC Engine Spridgets 3
I Resource for BMC/Leyland parts for Sprites? Spridgets 15
S Argentinian BMC Ute?? Other British Cars 4
B 100/6 BMC parts manual Austin Healey 12
K Colour Chart for Austin-BMC-MG...Jaguar? Triumph 3
sjuengst BMC affinity Austin Healey 0
theleisure BMC SPECIAL TUNING DATA Manual Spridgets 4
B BMC Training Unit Bus Other British Cars 164
BugEyeBear 1958 BugEye 1st Road Test Vintage BMC Video Spridgets 0
E Tip to remove the BMC on a '70 Midget Spridgets 6
TurnerSports222 Alexander Cross Flow Head - BMC Other British Cars 4
Luke_Healey Was this seat belt a real BMC part? Spridgets 3
H 1965 BMC AM Radio - no sound Austin Healey 5
John Loftus BMC fastener codes Restoration & Tools 10
Howard_The_Duck Posi-Ground BMC radio MG 5
B BMC Comps Dept new book Austin Healey 0
M Crosley with BMC engine-trying to identify it. Other British Cars 6
S BMC registry Austin Healey 12
rovernut Austin or BMC mini logo British Motor Corp 4
78Z check out this BMC/BL history site Other British Cars 3
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
