Tip to remove the BMC on a '70 Midget
EastTXMidget
Not to long ago I think I remember finding a thread that gave a tip on removing the Brake Master Cylinder from the pedal box. I can't seem to find it in the list. Is the a tip to getting the bottom bolt off with out having to remove the pedal box?
65sprite
Remove the cover plate, if you have one. then, remove the circlip from the clevis pin, remove the clevis pin and the 2 bolts that hold the mc to the pedal box. Disconnect the line and the mc should lift out.
JPSmit
For the second time now I read the title and think it has to be about a Japanese engine conversion since that's the only thing that I think could remove the British Motor Corporation (BMC) from the car - /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
bugimike
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif Me too!! /bcforum/images/%%GRAEMLIN_URL%%/grin.gif .
Morris
I need some tips for removing the "Leyland" from my "British" in my '79 midget.
GB1
If it was me, I would remove the rumph first.
Pat
drooartz
Put in a 1275...? /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
RickB Need Tip to remove stubborn headlight trim rings MG 3
JPSmit Today's top tip - Rain X Restoration & Tools 3
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
Geo Hahn General Tech Tip for DOT5 Users Triumph 9
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
Rob Glasgow A tip from You Tube Austin Healey 6
Gearhead_Garage Spare Tire Cover Tip Austin Healey 1
Gearhead_Garage Storage Tip for British Cars Austin Healey 10
S Hot tip: seal for fuel tank sender Austin Healey 9
Michael Oritt Rear axle tip needed Spridgets 6
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
glemon Tech Tip, Wonky Switches Restoration & Tools 3
H Su tip Triumph 7
JPSmit Cleaning Tip Restoration & Tools 0
Tinkerman TR2/3/3A Battery Box Liner TR3A Tip for the Day Triumph 5
jlaird Todays tip Spridgets 4
T Reminder on a top tip for stuck bolts Triumph 6
Trevor Jessie Eezi-Bleed Tech tip Spridgets 1
Basil Tip - Columns in posts FORUM Navigation Questions 0
apbos Undercoating Removal Practice Tip Restoration & Tools 5
B Spray paint tip Restoration & Tools 2
jlaird Need your tranny rebuilt - tip for the day Spridgets 1
jlaird Tip of the day - gaskets Spridgets 13
JPSmit Good Friday confession - and work tip Spridgets 8
J Tip lowered front suspension and bump stops Spridgets 0
jlaird Tip for today Spridgets 0
Jim_Gruber Heater Valve Leaking - Tip to fix Spridgets 10
jlaird Todays tip, Carbs Spridgets 5
M A tip for those new to Sprites Spridgets 8
D U-joint removal tip any TR Triumph 11
jlaird Another tip for Bugeyes Spridgets 2
jlaird Tip Spridgets 4
JPSmit An installation tip Spridgets 2
jlaird Jacks tip for the day Spridgets 0
jlaird Progress tip Spridgets 1
tomshobby seatback foam tip Triumph 8
sparkydave Random tip of the day Spridgets 2
Stewart Windshield cowl seal hot tip MG 1
SilentUnicorn 1500 Tip of the Day Spridgets 3
jlaird Jacks tip of the day, Spridgets 3
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
jlaird Doors don't fit right-tip Spridgets 3
jlaird More on choke cables-tip of the day. Spridgets 6
H TR6 TR6 Gas Cap Spring Tech Tip Triumph 4
1 Has anyone ever heard this tip? "Weeping" head MG 11
G AAARRRGH - anyone got a tip for these bushings? Triumph 11
jaybird The 'bird's Tech Tip #17 MG 42
jlaird Todays tip - Door hinges Spridgets 8
jlaird Jacks Tip of the day Spridgets 1
