Undercoating Removal Practice Tip
apbos
My replacement TR3 hood was covered with Asphalt Undercoating. The hood has no dents but I wanted to remove all the paint and then send it out to be lightly media blasted. How to remove the undercoating. In the Veterinary profession at our annual meetings we have a session where practioners get up and present their tricks of the trade. It is a wildly popular session and these tips can make your life much easier.
So here is mine. After using a little mineral spirits applied to the tar (a heat gun might have worked also), I used my Swiss hoof knife to quickly remove that cr*p. Took about 10 minutes. Not bad for a job that I thought would take days and make a mess that I would have to clean up for weeks.
Paul
Paul, Would a tack shop have them, or are they a specialty tool for your trade? PJ
apbos said:
M I used my Swiss hoof knife
great idea! effective increase in horse power too :devilgrin:
It will increase my power to weight ratio....I removed about a pound of tar.
You should be able to find a knife at a good tack shop or feed store. I used my regular hoof knife to get in the tight spaces. They are available online, but shipping gets increases the cost. The nice thing about the knofe is you pull a thin 1/4-1/2 inch strip. Pushing or pulling a paint scraper graps to much material and you can not get through the stuff.
Paul
Thanks Paul, Living in horse country, we have a couple tack shops close by. I'm going to pick one up. For cutting tar/undercoating off, a cheap one will do fine. Thanks again for the tip. PJ
Friends of mine swear by the heat gun. A low temperature warms the tar/undercoating and then you can take it off with a paint scraper. I prefer using a plastic scraper just don't aim the heat gun at it!
BTW- What is the general opinion of what to do after the tar/undercoating is off. I am inclined to treat any light rust with rust converter and rust encapsulator and they just top coat it with a good quality paint (flat black for frame). It seems to me that this would do as well as the tar/undercoater, and is less of a mess.
G Undercoating/sound deadening removal Spridgets 5
HEALEYJAG undercoating removal Austin Healey 7
J Undercoating removal Triumph 20
Gray_Cat Bed Liner As Undercoating Spridgets 2
E undercoating on BT7? Austin Healey 9
B removing undercoating Triumph 19
mijocan Removing undercoating Restoration & Tools 7
T TR2/3/3A TR3 undercoating? Triumph 16
E Bugeye Undercoating.....Lack Thereof? Spridgets 5
V Undercoating XK150 Jaguar 0
sparkydave Undercoating repair Spridgets 5
mcguijo TR2/3/3A Undercoating on TR3 Triumph 11
71tr Undercoating Alternative Triumph 1
L what about undercoating? MG 9
61Alpine Clearing the Undercoating Sunbeam (Rootes) 3
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
BoyRacer Door Skin Removal Austin Healey 6
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
C MGB Rubber Bumper cover removal MG 5
kodpkd Antenna Removal Austin Healey 9
B General MG Crankshaft Nut Removal MG 4
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
W BN1 Steering Box Removal Austin Healey 11
S TR2/3/3A engine removal Triumph 12
S TR2/3/3A Steering wheel removal. Triumph 4
D Clutch Fork Pin Removal Austin Healey 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
C MGA Dash removal MG 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AUSMHLY Spigot Bush, Pilot Bushing Removal Austin Healey 4
R TR2/3/3A Steering wheel hub removal Triumph 11
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
D Heater knob removal Spridgets 6
S 1275 oil pan removal Spridgets 30
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
E austin van heater removal Other British Cars 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
nevets Water Pump Removal Austin Healey 6
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
F Interior Door Handle Removal Austin Healey 2
Z Front Springs Removal Austin Healey 3
R Oil Filter Removal Austin Healey 1
C MGA R/H tail lamp removal on a 1962 MG 5
K TR2/3/3A Removal of tie rod end? Triumph 7
J Ignition Key Cylinder Removal Austin Healey 3
J Planetary Gear Removal Austin Healey 3
