Whilst stripping my frame/substructure I have run across some brush applied tar like substance on sheet metal behind diff, and above rearmost spring shackle points. It appears to be the only undercoating anywhere on the frame. There is only black primer between it and the metal. Anderson and Moment Write that there was never any undercoating applied AFTER the color coat, yet do not make it clear whether any was applied BEFORE the color was laid on. P,O. or original? thanx in advance... Roby
