Crane XR700 Electronic Ignition / BT7
Gibber
I was having issues with a misfire after long periods of idling, but once on the highway or after the car sitting and cooling off it ran smoothly again. The XR700 ignition had just enough wire length to put the module in the interior on the other side of the firewall to get away from under hood heat. This solved all the issues. However, the wires were stretched tight and the XR700 unit was just sitting on the glove box tray. I used the same gauge wire to the coil and ground and the 3 distributor wires in order to extend it about a foot in length so that I could mount it properly and route the wire nearly through the engine bay. Everything secured with heat-shrink connectors but no luck starting. Red light flashes on the module, but not firing. Would lengthening the wires affect the system?
Patrick67BJ8
I was having issues with a mis-fire after long periods of idling, once on the highway or after the car sitting and cooling off it ran smoothly again. The XR700 ignition had just enough wire length to put the module in the interior on the other side of the fire wall to get away from under hood heat. This solved all the issues, however wires were stretched tight and the xr700 unit was just sitting on the glove box tray. I used the same gauge wire to the coil and ground and the 3 distributor wires in order to extend it about a foot in length so that I could mount it properly and route the wire nearly through the engine bay. Everything secured with heat shrink connectors but no luck starting. Red light flashes on the module but not firing. Would lengthening the wires affect the system?
How did you splice the wires?
Patrick67BJ8
I used heat shrink connectors.
I have never used them, but instead I used non-insulated splices and either crimped or soldered them. I used heat shrink afterwards. It sounds like you have an “open” wire connection. You say you did this after the wire was stretched too tight. Check the connections on their ends.
G
Gibber
The heat shrink are crimped. I have checked all connections seem good and when I crank the engine the red light on the module flashes.
thanks for the response.
G
Gibber
My module (in my BN4) is on the engine side of the passenger footwell. It's cool enough down there.
I’ve had mine for about 10 years and in the last 3 I’ve had issues when long periods of idling. It was mounted on the distributor side by the firewall. Moving it into the interior solved the issues but I needed to extend the wires in order to mount properly.
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
RickB MGB Crane Cams XR700 Fireball - wet conditions? MG 7
B Crane XR700 Installation Problem Triumph 16
P Allison/crane xr700 install Triumph 1
Z Crane XR700 help needed, car won't run Triumph 27
PAUL161 T-Series Crane Cam MG 0
B Crane Cams Electronic Ingnition Austin Healey 9
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
PAUL161 General MG Crane Electronic Ignition MG 9
DNK Crane Ign MG 6
1 MGB-GT Engine hoist/crane boom length? MG 17
PAUL161 Hap, Crane cams? MG 6
bighealeysource Anyone using an Allison or Crane on your Healey Austin Healey 7
dklawson Bad Economy Forces Crane Cams to Shut Down Spridgets 7
dklawson Economy Shuts Down Crane Cams Triumph 5
T lotus excel ignition - can i run a crane hi-6 ? Lotus 0
S Pertronix Ignition VS Crane/Alisson Ignition? Triumph 7
bmurphy7369 Wiring help needed badly... 1975 XJ6 Crane setup.. Jaguar 8
bmurphy7369 XJ6 SII 1975 with Crane Ignition dies when warm Jaguar 10
tosoutherncars Crane ignition question Spridgets 15
A Crane vs. Pertronix ignition Triumph 9
Z RVI Tach w/ crane ignition? Spridgets 2
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Atrus Crane/Pertronix Ignition Question Spridgets 11
Sarastro Crane electronic ignition installation Spridgets 3
bravenrace Pertronix or Crane? TVR 8
Michael Oritt Crane XR3000 ignition system Racing 4
F Re: crane xr 700 optic ignition system question MG 10
V TR6 TR6 Crane Cam Grind# S-264-C Triumph 2
L Spark Plugs with Crane Ignition MG 10
A Help with electronic ignition [Crane] MG 11
R Crane Cams Electronic Ignition Module Austin Healey 5
K Crane Cam Spridgets 4
C Pertronix versus Crane ignition kits ? MG 7
Y Crane Vs Pertronix Austin Healey 5
G Pertronix vs Crane Ignition MG 18
H TR6 1974 tr6 allison xr700 Triumph 12
K Troble shooting Allison/XR700 Ignition Restoration & Tools 9
jvandyke pointless ignition XR700 vs. Allison Spridgets 12
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
TRickster6 MGB electronic ignition on '73 MGB MG 1
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Basil Electronic Clutch [Deleted] Other British Cars 9
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
O Sprite Petronix Electronic Ignition Spridgets 10
