Spark Plugs with Crane Ignition
LLAngus
What is the proper plug gap to use on a Crane Ignition? I am using NGK BP6ES. /ubbthreads/images/graemlins/driving.gif
L
LLAngus
Thanks, I'll give that a try. I just thought 25 thousands was a little close for the Crane ignition setup.
/ubbthreads/images/graemlins/yesnod.gif
Bugeye58
Sure is Bruce. You might as well take advantage of the extra ignition. You may want to try advancing the timing just a nudge.
Jeff
L
LLAngus
I can't believe it!! With the redone head and new plugs the acceleration is great and smooth. I need to adjust the valves again. I tend to set them a little loose until the motor is running. WOW took a trip down the road and back, I just can't believe the difference in the GT.
Bruce L
/ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/driving.gif /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/lol.gif
[ QUOTE ]
Bruce, I run the same plug and setup on a 1275 Midget, with the plugs gapped at .035". Works just fine.
Jeff
[/ QUOTE ]
Jeff would you suggest the same for a 1500/crane?
mark
L
LLAngus
Mark,
I would if he doesn't. I'm running a 1800/Crane. It fires beautifully.
/ubbthreads/images/graemlins/hammer.gif Bruce L
ok thank , duly noted, or should i say evernoted
mark
stolizino
Crane 3000. ".035".
L
LLAngus
What is the ohm rating for spark plug wires? Anyone know? I have a low power miss, now. /ubbthreads/images/graemlins/crazyeyes.gif
Keoke
LLangus;
Zero OHMS on a one-to-ten Ohms scale for spark plug "wire". 10,000 OHMS Max for the string stuff---Keoke /ubbthreads/images/graemlins/hammer.gif
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
kodpkd Spark Plugs Austin Healey 3
L TR4/4A spark plugs Triumph 9
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
tahoe healey Spark Plugs Austin Healey 20
G spark plugs Austin Healey 10
vickxxx T-Series 1952 MGTD spark plugs. MG 4
Simon TR4a TR4/4A Spark plugs, what do you use? Triumph 4
gbtr6 TR6 What spark Plugs do you use? Triumph 1
S MGB 1969 MGB No spark to plugs MG 5
R Spark plugs for 61, BT7 Austin Healey 2
M TR4/4A Spark plugs. Triumph 1
T TR4/4A What gap on Champion L-87YC spark plugs? Triumph 3
sim Dead spark plugs ? Spridgets 52
tinman58 General Tech Bad spark plugs Triumph 7
K TR2/3/3A NGK BPR5HS spark plugs I believe are one stage hotter.... Triumph 5
S TR2/3/3A TR3A Spark Plugs Triumph 4
JPSmit How often do you change your spark plugs? Spridgets 7
R Mixing spark plugs Triumph 10
B Spark plugs with Webers Austin Healey 6
Patrick67BJ8 Spark Plugs for '67 3000....what kind? Austin Healey 23
K TR4/4A NGK Spark plugs BPR5HS for TR3A/TR4A Triumph 3
Flash_Harry Any thoughts on these spark plugs? MG 9
B Spark plugs Austin Healey 3
M Spark Plugs!!! Triumph 13
D Read Spark Plugs Spridgets 21
fad64b NGK Spark Plugs Triumph 2
JodyFKerr Fighting with spark plugs in an Explorer Other Cars 19
Randy Forbes Platinum spark plugs...? Austin Healey 7
Musicman Spark Plugs - Champion or NGK Triumph 13
SkinnedKnuckles Lasers to Replace Spark Plugs... Triumph 1
S Spark plugs Triumph 20
M 100M spark plugs Austin Healey 2
TR6oldtimer Reading spark plugs as a tuning aid Triumph 19
R Compression/spark plugs Spridgets 13
TR6oldtimer TR6 TR6 spark plugs Triumph 7
Grampy spark plugs Racing 2
A no spark to plugs!!! Triumph 20
C Best Spark Plugs for BJ8 Austin Healey 14
