Re: crane xr 700 optic ignition system question
ferrmgt
Hi, love the forum
question, my 1977 mgb had a crane xr 700 optical ignition system installed years ago. it has worked perfectly until... a couple of months ago. finally have time to work on the car and am getting no where. I have no spark at the plugs, no spark at the coil, and no led blinks. I ordered another xr700 ignition and installe today. same problems. Anyone have any ideas? thanks for the help.
F
ferrmgt
Not Sure, how would I check that? I will look into it...
G
If you have 12 volts, did you replace the pickup in the distributor when you replaced the ignition. Mine quit one day due to water dripping from the heater valve on to the distributor which I tried drying out the cap first then after getting it towed home found dampness in the infrared pickup and by drying that out and cleaning it, got it working again. Also you might make sure you have a good ground.
Bob
jlaird
Bob, just thought I would say that top the same color as the car looks great. Are they supose to be the same color on Bs?
F
ferrmgt
bob,
thanks for the help, I did change the pickup (LED light source I think you mean) and to no avail. I think I will change the distributer cap and rotor just for good measure, since I dont know how old they are. I am interested in checking the power source to the ignition module but dont know how, do you?
michael
G
No, Jack, the original color for mine was black. The top was given to me by a friend of my son after I took him in when his mother kicked him out of the house. He brought it to me from up north strapped to the trunk of his american car. I painted it at the same time I painted my car in the same color which wasn't an MG color.It is a chevy color crimson red from 1996.
Bob
G
Michael, one of the wires going to it should have 12 volts on it. I will look at mine tomorrow and see which one does. Usually red but I will check.
Bob
jlaird
Well I must say that I like that red and even more think the top looks right painted the same color as the car. Suspose they did not paint tops so one would fit all, another bit of cost saving at the works.
G
Well, Jack, most people didn't buy the hard top when they bought the car. It was offered as an accessory so that would be the reason they painted them a color to match all colors. I agree that it loks better painted the same color as the car just like I think the rubber bumpers look better painted the same as the car but with the many different opinions we see just on this forum, immagine trying to satisfy the world.
Michael, I checked my XR700 and the red and yellow wires go to the coil. The red is on the + terminal and has close to 12 volts on it with the ignition switch on and the motor not running. The yellow is the ouput from the ignition and with the car running and the voltmeter on AC I read about 1.6 volts AC. This is most likely a square wave so the meter can only average it. A scope would show the real story. I only get 11 volts at the red lead but I checked the diagram and it goes through the tach before it gets to the coil so is probably dropped slightly through there.
Bob
F
ferrmgt
bob,
thanks, I will try to do the same this evening. Crane says by the way that a true 12 volts is needed to fire the led pickup. interesting, you have 11v and the guy on the phone from crane was strong in saying the led wont fire with out 12v? I will keep you posted.
thanks again.
michael
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
PAUL161 T-Series Crane Cam MG 0
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
B Crane Cams Electronic Ingnition Austin Healey 9
RickB MGB Crane Cams XR700 Fireball - wet conditions? MG 7
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
PAUL161 General MG Crane Electronic Ignition MG 9
B Crane XR700 Installation Problem Triumph 16
DNK Crane Ign MG 6
1 MGB-GT Engine hoist/crane boom length? MG 17
PAUL161 Hap, Crane cams? MG 6
bighealeysource Anyone using an Allison or Crane on your Healey Austin Healey 7
dklawson Bad Economy Forces Crane Cams to Shut Down Spridgets 7
dklawson Economy Shuts Down Crane Cams Triumph 5
T lotus excel ignition - can i run a crane hi-6 ? Lotus 0
P Allison/crane xr700 install Triumph 1
S Pertronix Ignition VS Crane/Alisson Ignition? Triumph 7
Z Crane XR700 help needed, car won't run Triumph 27
bmurphy7369 Wiring help needed badly... 1975 XJ6 Crane setup.. Jaguar 8
bmurphy7369 XJ6 SII 1975 with Crane Ignition dies when warm Jaguar 10
tosoutherncars Crane ignition question Spridgets 15
A Crane vs. Pertronix ignition Triumph 9
Z RVI Tach w/ crane ignition? Spridgets 2
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Atrus Crane/Pertronix Ignition Question Spridgets 11
Sarastro Crane electronic ignition installation Spridgets 3
bravenrace Pertronix or Crane? TVR 8
Michael Oritt Crane XR3000 ignition system Racing 4
V TR6 TR6 Crane Cam Grind# S-264-C Triumph 2
L Spark Plugs with Crane Ignition MG 10
A Help with electronic ignition [Crane] MG 11
R Crane Cams Electronic Ignition Module Austin Healey 5
K Crane Cam Spridgets 4
C Pertronix versus Crane ignition kits ? MG 7
Y Crane Vs Pertronix Austin Healey 5
G Pertronix vs Crane Ignition MG 18
J LED lights for PL 700 Restoration & Tools 12
AngliaGT Bmw 700 Spotted 2
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
B Seattle '65 Sprite on CL w/hardtop $700 Spridgets 1
RickB 64 Sprite MK3 on CL Turner Oregon $700 [nfi] Spridgets 0
I PL 700 halogen wattage? Triumph 29
tahoe healey PL 700 Austin Healey 2
tahoe healey PL 700 head lamps Austin Healey 13
I PL 700's - more tripod troubles Triumph 8
I Lucas PL 700 tripods Triumph 27
Banjo Corvair 700 Ebay gem Other Cars 6
bighly Nelson photos [A picture perfect 4,700 mile run] Austin Healey 4
