Undercoating/sound deadening removal
ghostgrunt
This very well may be old news to you folks,but I bought one of those "oscillating multi-tools" at HF at a deep discount. I wanted to use the triangular sanding pad to reach into some hard-to-get-at corners on my '72 Midget. As luck would have it,the tool only comes with a small wood-cutting blade,and HF was sold out of the triangular sanding pad adapter thing. However,they did have scraper blades in stock. Holy crap,those things are my new favorite implement of destruction. They cut through undercoating like no tomorrow. It stripped that tough as s#@! stuff off the tranny tunnel,too--a job I was dreading,but I had to inspect those seams at the floorpan for rust. Anyway,if this isn't old news to you,give it a try--I'm mighty happy with it. Some mineral spirits on a Scotchbrite pad and wipe down w/shop towels make short work of any residual muck.
Might have to try it. My tool of choice has been a heat gun and a putty knife. I despise undercoating.
Same here, good to know. I always used 5 gallons of gas and a book of matches.
I bought the Dremel version, and as a cabinetmaker, I'll say that is it the right tool for a bunch of jobs. I wish they were around 30 years ago ! I also understand that dry ice works well, too.
Ah....Believe there are laws against open burning in most states!!!
Kurt.
I know;everyone's got their own recipe/method for undercoating removal. Diesel to dry ice,heat gun and putty knife(yeah,I've done that,too). It's always been such a tiring,slow process. If there's a better mechanical method to remove this stuff,I don't know what it is. Once I saw how quickly I was able to cut that crud off the floorpans,I was actually enjoying the job! Anyway,I hope it works equally as well for any of you who try it. I'm now a lot closer to having the body tub squared away and beginning the reassembly of the car.
Gray_Cat Bed Liner As Undercoating Spridgets 2
E undercoating on BT7? Austin Healey 9
B removing undercoating Triumph 19
apbos Undercoating Removal Practice Tip Restoration & Tools 5
mijocan Removing undercoating Restoration & Tools 7
T TR2/3/3A TR3 undercoating? Triumph 16
HEALEYJAG undercoating removal Austin Healey 7
E Bugeye Undercoating.....Lack Thereof? Spridgets 5
J Undercoating removal Triumph 20
V Undercoating XK150 Jaguar 0
sparkydave Undercoating repair Spridgets 5
mcguijo TR2/3/3A Undercoating on TR3 Triumph 11
71tr Undercoating Alternative Triumph 1
L what about undercoating? MG 9
61Alpine Clearing the Undercoating Sunbeam (Rootes) 3
Patrick67BJ8 Insulation and Sound Deadening Austin Healey 0
M TR6 Clicking sound when accelerating Triumph 11
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
nichola TR6 Stock exhaust sound... short video Triumph 4
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
J TR6 Does this sound ok to you? Triumph 5
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
DerekJ Sound proofing recommendations Austin Healey 8
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
maxwedge5281 no sound when breaking the christmas bulbs??? Austin Healey 16
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
C A better sound for a Miata? Other Cars 0
GTP1960 TR2/3/3A Loud scraping sound in clutch area Triumph 12
T sound for a bug-eye??? Spridgets 2
N MGB-GT Carpet, sound proofing, and painted bumpers, Oh My! MG 15
W Sound 1966 Sprite rolling chassis Spridgets 0
HealeyRick Alternative Sound Systems Restoration & Tools 2
AN5Sprite F1 Sound Comparison 2013 vs 2014 Racing 2
Boggsy64 MGB Sound deadener MG 4
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
M Replacement Sub-Woofer for X308 99 XJ8 with Premium Sound System Jaguar 1
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
JPSmit What is that strange grinding sound in the distance? Spridgets 3
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
KVH Strange Sound Like Compressed Air Escaping Triumph 14
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
P Engine noise ~ Garbage disposer sound Triumph 9
Kleykamp TR2/3/3A clanking sound at idle on TR3 Triumph 17
7 squealing [Humming] sound rear DRUM brakes Other Cars 3
M Sub-woofer Speaker for 99 XJ8 with Premium Sound Jaguar 1
regularman heard a clicking sound and found the cause Spridgets 6
