MGB Sound deadener
Boggsy64
I plan to put down Dynamat or some other asphalt based deadener in the cabin of my B. I thought I would just put it over the factory deadener that is on the floor pans. Have read, and it makes sense, that this old deadener needs to be removed or water can get in there. I have read about using chisels and stripper / thinner to get the old stuff out, even dry ice. Anyone have a quick way to do this job? It appears to be dried up tar / asphalt.
A putty knife the width of the recess and a heat gun. Heat the old strips starting at one end as you go and they should come up. It isn't a fast or pleasant job, but it worked for me. Once removed, mineral spirits cleaned the rest up. PJ
I bought an oscilating tool for the undercoating on the Vauxhall and love it. It is also my best friend for our never ending bathroom reno. https://t.harborfreight.com/power-tools/oscillating-tools.html
BTW before you go crazy ask yourself if your car has the opportunity to get moisture in which, if left unchecked, starts to rust? This may be an issue that is no longer an issue due to your driving habits.
JP, you are exactly right and that is exactly what I thought when I looked at it again last night. At this point I will be applying the new material right on top of the old. The new sheet material with adhesive backed sheets should seal pretty well. Besides the old deadener panels fill in the floor pan embossing ridges, and without it the floor would be convoluted under the carpet.
Always nice to see a job simplified - and of course pictures are always welcome even for mundane jobs!
Patrick67BJ8 Insulation and Sound Deadening Austin Healey 0
M TR6 Clicking sound when accelerating Triumph 11
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
nichola TR6 Stock exhaust sound... short video Triumph 4
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
J TR6 Does this sound ok to you? Triumph 5
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
DerekJ Sound proofing recommendations Austin Healey 8
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
maxwedge5281 no sound when breaking the christmas bulbs??? Austin Healey 16
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
C A better sound for a Miata? Other Cars 0
GTP1960 TR2/3/3A Loud scraping sound in clutch area Triumph 12
T sound for a bug-eye??? Spridgets 2
N MGB-GT Carpet, sound proofing, and painted bumpers, Oh My! MG 15
W Sound 1966 Sprite rolling chassis Spridgets 0
HealeyRick Alternative Sound Systems Restoration & Tools 2
AN5Sprite F1 Sound Comparison 2013 vs 2014 Racing 2
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
M Replacement Sub-Woofer for X308 99 XJ8 with Premium Sound System Jaguar 1
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
JPSmit What is that strange grinding sound in the distance? Spridgets 3
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
KVH Strange Sound Like Compressed Air Escaping Triumph 14
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
P Engine noise ~ Garbage disposer sound Triumph 9
Kleykamp TR2/3/3A clanking sound at idle on TR3 Triumph 17
7 squealing [Humming] sound rear DRUM brakes Other Cars 3
G Undercoating/sound deadening removal Spridgets 5
M Sub-woofer Speaker for 99 XJ8 with Premium Sound Jaguar 1
regularman heard a clicking sound and found the cause Spridgets 6
bugedd The sound of silence Spridgets 9
M exhaust sound different. brith/jap Spridgets 14
T Scraping sound and puddle Triumph 2
T What do these symptoms sound like to you? Triumph 22
DNK Por 15 & Sound Proofing Triumph 9
Musicman Strange Clicky/Tappy Sound Triumph 6
DNK Out in the Sound... Spotted 3
tr5er sound problems Triumph 13
G Healey Sound Austin Healey 15
RichBall Oh, That Sound Spridgets 19
DNK 'Nother Dreaded Sound Deadening Question Triumph 19
Gundy New video w/ sound Spridgets 22
Superwrench sound deadening Austin Healey 2
7 New Day...New sound...This one sounds awful Triumph 12
BugeyeNJ58 Klunging sound on deacceleration Spridgets 7
