Strange Sound Like Compressed Air Escaping
KVH
I have a new issue to sort out.
In my TR4A, with OD, when I travel at high RPMs and then slow down and apply the brakes I'm at times hearing what seems to be the sound of compressed air escaping. Maybe something is rattling in the driver's side rear drum brake, but I've not yet been able to isolate the issue. I was even wondering if it's the pressure escaping from the overdrive unit, then building back up--but that's fluid pressure, not air (unless my fluid is low, I wouldn't think that could be the problem). Is there any reason to suspect the OD unit?
It's a bit like when you remove the air chuck from a compressed air line. A few times it seemed to be coming from my foot-well, driver's side, but then more from behind me.
This happens when the OD is not engaged. I've not even tried to listen while it's engaged.
Any better ideas?
alanjohnturner
OD does not make compressed air noises. You will see on a parallel thread that I ran mine on a test-bed so I found out what goes on with these.
Have you got a brake-servo fitted? Not original on UK spec cars but lots have em.
Al.
TR3driver
Great Pumpkin - R.I.P
Just a thought: Could you make a recording of it for us to hear?
KVH
KVH
Andrew, it's a one-time pop and I hear it when I just start to brake. I'll go for a run tonight and listen closely again.
HerronScott
Normally no brake servo on a TR4A although someone posted pictures here of a TR4A in the UK that had one a couple years ago.
Scott
JPSmit What is that strange grinding sound in the distance? Spridgets 3
Musicman Strange Clicky/Tappy Sound Triumph 6
johnrip Wedge TR7 strange sound Triumph 7
J A strange sound from under the hood! Austin Healey 18
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
E TR6 Strange Steering Rack Cap Triumph 3
Vargus TR2/3/3A Strange dents Triumph 19
nicko Strange Engine Noise Austin Healey 7
jlaird MGB Strange daily question. MG 10
C MGB strange?? MG 3
J TR2/3/3A such strange thread on gear shift knob Triumph 12
7 Strange A/C - radio problem Other Cars 7
S TR2/3/3A Strange part Triumph 3
steveg Strange gasket pieces Austin Healey 5
steveg Strange Oil Leak Austin Healey 7
D TR2/3/3A Strange hole! Triumph 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Michael Oritt Strange debris found in sump Austin Healey 19
F TR2/3/3A Strange Loud Noise Triumph 11
C Strange...can won't start and then magically ressurects Austin Healey 16
bighealeysource Strange problem with throttle staying open Austin Healey 6
D TR2/3/3A Strange Transmission Issue Triumph 9
Rhodyspit75 Strange windshield washers Spridgets 0
tahoe healey strange OD question. Austin Healey 9
andrea Very strange austin healey 3.9 Austin Healey 5
M Strange Healey Tach Austin Healey 9
Rut Strange occurance! Spridgets 19
aeronca65t Big Healey-strange wheels Austin Healey 12
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
J TR4/4A Strange question that may involve the coil- Triumph 13
jlaird Todays strange question Spridgets 6
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
B Strange rear light Other British Cars 6
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
B SU Carbs have strange vacuum fitting Triumph 17
Kleykamp TR2/3/3A Strange TR3 side curtains ??? Triumph 13
HAN8L1965 Strange event ? Spridgets 6
T strange litter Triumph 5
aeronca65t Strange and interesting MGs MG 3
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
W Strange occurence Spridgets 5
P Strange clunking noise Triumph 20
bugedd Strange trans noise Spridgets 7
SilentUnicorn Strange things British Motorbikes 4
Bremer Strange, but interesting... factory blunders? Triumph 8
M another strange bugeye on ebay Spridgets 12
JAV strange noise Austin Healey 4
J Strange electric problem. Jaguar 11
