Since signing up last year I've read the forum almost daily but haven't contributed much. I have a daily driver Mark II Sprite with a 1275 engine, and have found that the only way to keep it on the road is to do the work yourself. I now regret not taking 9th grade automotive mechanics! But I'm learning (through the forum) and driving the Sprite about a thousand miles a month around western Connceticut. For the most part the engine purrs but recently, starting about 3500 RPM a strange sound begins that sounds like something is loose and sporadically clanging against metal. Almost as if there were a metal tag flapping around. I've been looking for something loose until going down a hill today I put the car in neutral and coasted. The sound stopped. When I got home I lifted the hood and revved the engine to 4000 RPM and the sound seems to be coming from the fan. While the blades are not loose, there is some play in the assembly. Could it be that there is not supposed to be any play there? I couldn't find any reference to this in the books although Glenn mentions a bent and out-of-balance fan as being a cause for accessory noises. It doesn't look bent and how would you tighten it?
Jack
62 Sprite
95 Miata
Jack
62 Sprite
95 Miata
