BT7 Panhard Rod
Healey Nut
So one end of the Panhard rod connects to the driver's side rear axle. Where does the other end go?
Pics anyone, pls?
John Turney
There should be a bracket on the right side frame rail with a hole. It is on top and at the outside edge of the rail.
Healey Nut
Healey Nut
Ah ha , mystery solved I have a Jule superstructure so no bracket on the frame rail so no panhard rod for me .
Anyone need a panhard rod and axle bracket with all new bushings etc ?
Its years since I got this superstructure from Marty at Jule and I vaguely remember him saying something about not needing the panhard rod due to his frame design and spring setup .
Anyone else out there with a BT7 and Jule frame etc care to chime in ?
DerekJ
Martys frames are based on a BJ8, or they were when I had one. BJ8s don’t have a panhard rod, instead they have two radius arms to locate the axle. Are you planning on installing these?
Healey Nut
Healey Nut
The panhard rod bracket for the chassis rail is available. So I could if I wanted buy the bracket and weld a plate between the base edges then drill tap the chassis rail and bolt it to the chassis rail to create the end connection for the panhard rod .
but it does seem though as if it’s not required with the Jule frame set up .
steveg
There's a thread here several years ago where Martin discussed the toe-in (IIRC) of the late BJ8 rear springs (and those of his Jule frame) and why in his opinion they made the Panhard rod unnecessary.
John Turney
The bracket should probably be welded, rather than bolted. In 2019, when repairing my rear axle, I found my Panhard rod was bent (I already replaced it) from excessive side loads.
vette
I believe I remember Marty saying that it was because of the extra strength of the leaf springs he uses that the panhard rod is not necessary. Most American cars did not use them but then most American cars were not called to hang turns like a sports car. I personally believe in a panhard rod as an easy and inexpensive way to laterally locate the rear axle. And for a sporting car I believe the rear axle should be located by more than just the springs.
BoyRacer
I agree. Add the panhard rod. The leaf springs alone are not sufficient to keep the rear end properly located during hard cornering.
bob hughes
The panhard rod on my BJ7 was bent so during the rear end refurb, I removed it to straighten it, but found that one end was severely corroded, rather than buy one in, I have made one from stainless steel so that will last longer than the rest of the car :LOL:
Cheers
Bob
BoyRacer
Does anyone know the exact amount of leaf spring toe-in that Marty put in his chassis'? Are the mounting brackets still parallel to the chassis or are they angled to align with the now toed-in leaf springs?
I have done some research in the past on this subject. Some American cars and trucks have had rear leaf spring toe-in. I one case I read about a vehicle that had 3" of toe-in although that is certainly the extreme. Toe-in will resist spring twist and lateral load but It will also increase roll stiffness. Increased rear end roll stiffness will also induce oversteer, also known as looseness....... which can result in spinning out. Installing an anti-roll bar (sway bar) on the rear will also increase roll stiffness and that is why I strongly recommend against it in a big Healey. Other cars that have different handling charactoristics may benefit from a rear bar.
vette
I really can’t answer your question but, I seem to remember a conversation here on BCF that someone believe leaf spring toe in might be about 1/2 inch. I can’t even say whether that was at each spring or was a total for both springs.
I think your description of the suspension tuning is accurate. In my mind I would rather work with a sway bar that relocating the spring perches. Having said that it seems to me that the proper way to move the spring perches would be to align them with the angle of the leafs. Any other way would induce premature wear on the perch bushings . IMO.
GregW
Martin's name here is frameman. I tried searching his posts on my phone but only got the supercharged Healey post. Maybe someone on a desktop can find the toe-in thread with him in the member field of the search.
Healey Nut
Healey Nut
You have to remember that Marty has since passed away so his posts may have been removed .
Healey Nut
Healey Nut
I will take some measurements off my superstructure and report back .
********Just took my boxes over to my shop and a quick measurement tells me the rear springs are parallel to the frame rails .
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
F Heater pipe and air duct routing BT7 Austin Healey 3
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
F Help need reinstating my heater - BT7 Austin Healey 7
AH67 Air Cleaners for Mark I BT7 Austin Healey 4
