TR2/3/3A TR2 Axle/wheel bearing removal
ccgunn
As I said in my "new member" introduction, I have owned my 1954 TR2 longdoor since about 1985. I did a restoration (not frame off) about 2002 - 2007. After my last ride (2011), the left rear wheel began leaking badly. I replaced the oil seals in both wheels. Then, of course, they both started leaking. So, the car sat while I dealt with some health issues. I am now back at it.
I initially had some issues getting the rear brake drums removed, but they were resolved after liberal use of penetrating oil. I have now removed everything down to the axles and wheel bearings. I am trying to remove the axle shafts, as per the Service Instruction Manual for the TR2. (3d Edition, 6th printing). I am also using the Haynes book for Triumphs. I have the earlier style of TR2 axle. One interesting item to note: when removing the nut and washer on the left side, I found 3 shims behind the washer. They were made from a Budweiser can, so I know that they are not original.
Emoji
Not sure why, but I will probably put them back. The left side is not the side that was originally leaking, but it is the side where the axle itself moves in and out.
I dismantled the brakes, took out the 4 bolts holding the hub to the axle casing, and expected to be able to just pull the axle shaft out, as the manual says. But nothing budged. I then pounded a thin paint scraper between the hub and axle casing. That was the only place that I could see where it could come apart. It did, and I removed the hub, but no axle shaft. The oil seal came out with the hub, but the wheel bearings are still attached somehow. The left axle shaft does spin, and does push in and pull out about 1/4 inch, or less. The right axle shaft spins, but does not move in or out. It appears that the left axle is different from the right axle. There are some cross markings on the right axle. Not sure why. Maybe it was replaced by the PO? I thought the the bearing and seal and hub needed to be pressed onto the axle shaft.
I don't remember the specifics of replacing the oil seals previously. Evidently, I ran into the same problem before, so I just installed the oil seals, and then reassembled.
In looking at the oil seals I just removed, it looks like part of them have never seen any oil. They are completely dry. Yes, I have kept the rear end full, and have greased the grease fitting. Also, it does appear that the wheel bearings have been replaced before (not by me), as they are marked "made in the USA" The reason I wanted to take the axle shaft out is twofold: 1) I like to follow instructions, and that's what the manual said, and 2) I wanted to look at the wheel bearings. I know that the right wheel bearing will have to be replaced. Even though I can't seem to remove it from the axle casing, I can tell that it is buggered - probably by the person installing it.
So, what am I doing wrong? Why doesn't the axle shaft just slide out, as the manual says? What am I missing? Any help would be greatly appreciated.
I have taken some pictures, and have uploaded them to my Flickr site, in an album labeled "TR2". They are at the end of the album. I also included pictures of the rear axle drawings and instructions from the manual, plus "Service Diagnosis" (Troubleshooting). The breather is, and has been, clean.
The link is: > TR2 <
I tried to take pictures of everything, including the left axle shaft "pulled out" and "pushed in". There's also pictures of the Bud shims.
Thanks again, David
CJD
Well, the first thing I notice is that you have sealed bearings. That is not normal and explains why the seals are dry. The axles will come out with the bearing, but you may have to reinstall the hub and nut loosely so you can use a puller. It should pull out easily.
DavidApp
Have you looked inside the differential to see if the PO did something in there that is holding the axle in place?
It looks like it should just pull out.
David
A Wanted Girling Axle for TR2 Triumph Classifieds 5
C TR2/3/3A TR2 Rear axle setup Triumph 1
C TR2/3/3A TR2 rear axle disassembly Triumph 13
2 TR2/3/3A TR2 Lockheed axle? Triumph 9
TRJohn TR2/3/3A TR2 rear axle woes Triumph 6
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
