TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block
1955TR2
I am encountering an oil leak problem that should be simple to fix but has me stumped.
I recently got my car back after some body and mechanical work was done on it which included an engine rebuild and reconnecting the oil sending unit. There is a fairly significant oil leak coming from where the oil sending pipe connects to the block. My initial thought was someone may not have installed the copper washers correctly because there is an inner and outer washer. I ordered new inner and outer copper washers from Moss and today I replaced these two washers and triple-checked I installed them in the correct order. I also replaced the stud end cap at the same time. Unfortunately, when I started the car to test if this fixed the leak to my surprise the leak is still there. I double-checked the tightness of the cap and retested but it's still leaking.
Does anyone have any ideas how to stop this leak/what might be causing this to still be leaking? Thank you.
CJD
Is it possible the stud is too long...allowing the nut to bottom before it is tight on the banjo?
mctriumph
It is not unheard of for the nut to crack if the stud is too long. Double check the banjo
for a cracked joint where the line is brazed.
Mad dog
1955TR2
1955TR2
Thank you Mad dog...either of these suggestions could be what is causing the leak and I need to investigate.
broken wrench
Bronze
When I built my 3 motor on startup I had that leak. It turned out that the stud was not so much to long, I just hadn't installed it all of the way in. Removed it, cleaned everything, re-installed it, and all was well.
Steve
1955TR2
1955TR2
Hi. I was able to finally fix the problem.
First, I ordered a new banjo and pipe. Next, when I installed the new banjo and pipe I added a second outer washer just in case, as in your situation, I wasn't getting enough pressure on the inner washer for it to seal properly. I also applied a thin coat of Permatex Aviation sealant to all of the washers. I'm not sure which of these things, or if it was a combination of everything, resolved the issue I was having, but I can happily say the leaking issue has been fixed!
Sarastro
I am continually frustrated by things like this that should seal, but don't. I had a continuing problem with the screws in the oil gallery, on the side of the engine, leaking. New copper washers didn't help, and I even put the screws in a lathe and turned down the mating surfaces. The surfaces in the block were smooth and unscratched. I eventually sealed it by doing pretty much what you did, new washers and a little Permatex Aviation sealant. Plus, a lot of torque.
60 PSI or so in the oil gallery ain't exactly the highest pressure ever recorded, but it is enough that the oil will doggedly find its way through any little scratch, unevenness, or other imperfection. I think you just have to keep trying things, as you did, until something works.
CJD
Glad you found the problem! Leaks like that on very old cars are often scratches or mars on the fittings. A copper gasket can only conform so far.
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
M General Tech TR2 Slave cylinder Triumph 0
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
