TR2/3/3A TR2/3 Guru Final Exam
CJD
Alright, here is a chance to test everybody's diagnostic skills. The TR2 has started making a noise. This will be a contest to see who gets the problem first. I'll start by saying I currently have no idea what the noise is, so I can't play favorites, even if I wanted to. And I don't plan to work on it until the temperatures come down below the 100+ here in Texas, so the symptoms and checks you recommend will come to you real time as I am able to work past the heat wave.
In the mean time, let's see who can hit the problem. To make it interesting, the winner gets to pic a free part from my TR2/3 collection! So, here goes:
First, the car drives and feels absolutely perfect. It runs, cruises, and stops just like a new TR2 should.
Last week it began making a dull grinding noise when starting from a stop in 1st gear. It just happened all of a sudden...one second didn't make the noise...the next it made it at every start in 1st gear.
It only does it after the engine warms. It does not do it for the first mile following a cold start.
Once it starts doing it, it will do it at every start. It is a gravelly, grindy sort of an inconsistent noise, like something is dragging. It lasts until about 5 mph, and then quits.
It never makes the noise in 3/4 gears. Occasionally you can barely make it out in second...but only rarely. It also makes it sometimes in reverse...so only a low range noise.
I can duplicate it at will by stopping and starting. While doing this and hanging my head out the door like Momma said not to, it seems to come from between the rear of the engine and front of the axle. That's as close as I can pin-point it.
It doesn't make any noise if I just operate the clutch without putting the car in gear.
That's the initial symptoms...I'll check/test anything you guys recommend and report the results here.
Good Luck!
CJD
CJD
Ah Ha...the exam begins.
Well, layshaft and bearings have fewer than 500 miles since new. The noise disappears completely over 5 mph while still in 1st gear. Pretty much by the time the clutch is fully out on a start the noise is gone. Then no noise going through 2/3/4 and OD. If you recommend a test I'll try it out.
Here is the layshaft going in with a brand new reverse gear:
CJD
CJD
That’s a thought, Marv. The dip-stick shows the tranny full, but I suppose if the reverse gear was moving to contact the 1st gear just slightly it would make a similar noise. Normally the reverse gear would be disconnected from the other gears except when reverse is selected. I can’t think of any way to check that without opening up the tranny...so hoping it’s something outside of the gearbox and would like to check more before opening the box up. It does shift into reverse just fine, so the linkages have to be lining up and the shift rod detents seem to be holding the forks in place. The reverse gear was brand new during the rebuild, with a new bushing in it, so not likely the gear or shaft wobbling:
Another clue I thought of...I changed the tranny fluid 150 miles ago and there were no chips or metal in what came out. The noise didn’t come on gradually. It started after leaving one stop light and has been doing it ever since...just in the initial 1st gear acceleration. If I wind the car up to 20-25mph in first the noise is gone, usually by the time the clutch is full out. But the clutch doesn’t make any noise if I operate it with the tranny in neutral.
Rhodyspit75
Since it only happens after a stop, could be brake related.
TomMull
John,
I'll be following this with some interest as my Herald makes a similar noise but only occasionally. My guess is that mine is a u-joint (6 possibilities on the Herald) but that is quite unlikely in your case with the new drive train. At any rate, it will be interesting to see how this turns out.
From your description though, I'd have to second Geo's guess, the lay gear bearing failures I've had fit pretty closely to your symptoms. I'd certainly start by checking the tranny oil for metal.
And I guess I should really start pulling the driveshafts out of the Herald.
Tom
Popeye
Bronze
I am a resident idiot here - having never been inside a gearbox. But here are my questions / thoughts anyways:
  • Does the noise happen if the car is started from a stop in second gear? (You mentioned no noise in 3/4 gear, but I assume that is not from a stop?)
  • You mention the noise only happens after one mile of driving. Is it possible to warm the engine but not the gearbox ... warm it up while holding the clutch to keep everything inside the gearbox from spinning? (Ignore wear and tear on the throwout bearing...)
    • Point being, this suggests a thermal issue; something is moving to cause the grinding - i.e. not "something broke", rather "something is out of alignment" (could be because something broke, I suppose).
  • Any changes to the level of noise if starting uphill or downhill? (Not sure where in Texas you live... here in Pittsburgh that would be an easy test with all the hills!)
  • How loud is the noise? You mention the noise goes away at 25 mph in first gear. Is this because the engine / wind noise is strong enough you can't hear the grinding noise, or is the noise that loud?
Again, just some thoughts to help target the issue.
M_Pied_Lourd
I will go with driveshaft rubbing something for $1000, Alex.
Cheers
Tush
donbmw
My thoughts from my experience. Can’t remember what shaft. Tooth broke of and made a noise only in first and reverse.
CJD
CJD
Some very good suggestions! I'm assembling a list of things to look at. Not to short the tranny guys, I'll check that eventually, but only after we've exhausted the easier things to check...but your diagnostics are in the hat! Here's the list so far:
1) I'll pull the wheels and drums to check the brakes to test Rohdyspit's brake idea.
2) I'll spin the drive shaft while on jacks to test Tom's U-joint theory.
3) I'll check closely for clearance around the drive shaft to test Bob's suggestion. (we'll have to have a runoff exam Between Tush and Bob if it turns out to be a non-muffler interference?!?)
4) I'll dial indicate the pinion and axles on the diff to see if Redoakboo is correct.
5) Try warming the engine with clutch in to see if that makes the noise start sooner to give clues to Popeye.
6). I’ll pull the clutch inspection plate to see if it has been rubbing on Steve’s suggestion.
7). Check engine and tranny mounts for failure/loose to test PeterK's possibility.
Geo, Marv, Don and BNW will have to wait patiently while I rule out the other items.
Steve will need to explain his thought in more depth, to see if it counts as a separate idea from Geo's diagnosis.
To answer Popeye's questions:
--No noise starting in second gear. If it does make noise in second it is always as the clutch comes off with a bit of a jerk.
--We don't have real hills here, but gentle slopes up and down driveways, say, do not seem to affect the noise...it occurs letting the clutch out going up or down.
--To clarify, the noise always stops by about 10mph while accelerating. It is about as loud as if a metal cover were dragging the ground, so loud enough to get the attention of pedestrians nearby or to hear over engine or wind noise. Even in 2/3/4th gears I have never heard it above about 15 mph.
Yes, as the participation grows so does the excitement! I'll run the above list this weekend to see where we stand!
pdplot
Had a similar problem in the Alfa. Only from a dead stop in first gear. Never did find out what it was but it has not reappeared - yet.
vette
John, just to make sure, try to pull and push your rear end pinion flange In & Out. Just to make sure your ring and pinion didn't move. Sounds crazy but on a new build I have had that happen to my Healey after 100 miles or so. The shim and spacers can get cocked and then slip into place there-by causing clearance.
sp53
Oh it is basically the same as Geo’s-- just that I have had that problem before on the shaft and it was the needle bearings on the ends of the shaft. I cannot remember if the bearing had too much play in the case or if they were scared with that galling. I have seen that tin inspection plate on the bellhousing come loose and make a weird sound also. Hopefully it is something easy like the tin piece.
sp53
To me the noise sounded like an old truck with a low granny gear and then once it got some speed it stopped. I think the shaft movement balanced it out. I wonder if you put some heaver oil in the tranny temporarily to see if that makes a difference.
CJD
CJD
Vette, your on the same path as Redoakboo...but if it checks out you’ll deserve a runner-up prize for being much more specific!
Steve, i’ll Add an extra check for your clutch inspection plate. I did have to spend a good bit of time straightening the plate last year, so that’s possible.
I can’t rule out the countershaft/bearings...but I can say the box sure seems to operate great with no noise any other time...so I’ll save opening it up for a bit.
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
