TR2/3/3A TR2 color questions
Philthytoo
Member
I'm in the very early stages of a TR2 renovation, and wondering if there's a way to know the original color from the numbers on the tags. TS2602L, there are two brass tags on the firewall; EB2557 over 728559. The car has red painted over white, but since there is red on the firewall and under the fuel tank,I'm wondering if the white was a color change from original red. Eventually the body is gonna get stripped, so I'll find out more later, but I'm curious.
Thanks, Phil
GilsTR
Phil
With your TS number you can get a British Motor build certificate.
You will learn the build date....original exterior color... as well as
interior and weather equipment. This can be ordered online.
Obviously becoming a VTR member also very valuable.
The real authority on specifics on the TR2 is available to you.
Good luck with this special project.
Gil. NoCal
Lou Metelko
Congratulations on starting the long road to restoring a Long Door TR2. None of the three tags will give any clue to its original colors and trim. Only way to get that information is to write to the British Motor Industry Heritage Trust. Small fee for the information but they will send you a neat frameable "birth" certificate. Others will give the link so that you can order the certificate. Many of us have been down the road you are starting on so don't be bashful about asking for advise and be sure to post pictures as you progress.
Lou Metelko
Auburn, Inddiana
54 TR2LD TS981
2long
You can research the original body color and fitments with a heritage certificate. It costs a bit of money but good to have! For your car, I don' think red was an original option (white was).
Dan
Mickey Richaud
Phil -
Bill Piggott's book, Original TR, is a great resource for all things TR. Also, you might want to hook up with the Vintage TR Register, as Gil mentioned above. Here's what they have to say about TR2s: https://vintagetriumphregister.org/tr2/
Lou Metelko
If you go to the above link it will open to a shot of my dearly beloved TS981. Believe it or not but that is the photo rendition of Ice Blue in direct sunlight. The photographer, Blake Discher, begged forgiveness for the "white" showing. The photo was taken about 2005 in Detroit.
Lou Metelko
Auburn, Indiana
Geo Hahn
Mentioned above but a link may help: https://www.britishmotormuseum.co.uk/archive/heritage-certificates
As noted, I do not think early cars were available in red. The story I heard was that Cal Sales / Dorothy Dean were painting new TRs red upon delivery as that is what was selling well in hip & sunny California. The factory learned of this and eventually started delivering red cars. Maybe things have changed but the photo on my garage wall of the show field at the 1987 TRA is over half red TRs. Mine is red but I'm on overload and prefer to see them in other colors.
ckeithjordan
According to Piggott's book and other VTR documentation, Signal Red was available starting with TS1201, April 1954, along with British Racing Green. Prior to that, the very earliest TR2s were available only in Ice Blue, Geranium, Olive Yellow, Pearl White and Black.
ckeithjordan
+1 on Lou's suggestion. The VTR website has info on ordering the certificate and you can also order a Factory Trace which has much of the same info. Here's the link: https://vintagetriumphregister.org/trace-certs/
The page shows both the certificates and the trace, so you can see what each one has.
P
Philthytoo
Member
Thanks for the info! I'll be sending off for the certificates, I think they would be nice to have in the file. Kinda like the line-set tickets for my Scout.
Happy Holidays to All!
Phil
TomMull
Phil -
+1 on Piggott's book. Here's a source link to the version I have. Some discussion of early colors included. Seems to be getting pricey but well worth it IMO.
https://www.amazon.com/Original-Triumph-Tr2-3A-Vol/dp/1901432033
Tom
GilsTR
For sure I join the vote for Piggotts book.
Met a new TR3 Small mouth owner this past Summer.
He had just been given his grandfathers old race car.
I found a Piggotts book online promptly.
World of information in that gen.
Got him started on the right track.
Gil. NoCal
Redoakboo
I have a 54 TR-2 Long Door TS 3359 LO. I just got the Standard Register on my car. It left the plant Triumph Racing Green. I am presently restoring it and it with be painted Triumph Racing Green.
Dick
P
Philthytoo
Member
Thanks,
The Amazon listing referenced also shows a second book, "Triumph TR2, 3 &3A in Detail," by the same author. Is one of these a continuation type thingy, or are they two completely different books?
Does anybody know if the factory used red primer under the original paint? I've found a couple spots that look like the car was blue, then white, then red. Red primer would explain the color under the dash and fuel tank.
Thanks Again,
Phil
ckeithjordan
Phil,
The "...Detail" books is different and more recent (2008). It has history on the TR2-3-3A-3B, with lots of side items in different chapters. Also has chapters on the Le Mans TR3S and the cars in competition.
I have both books and consider them worthwhile additions to the TR library.
P
Philthytoo
Member
Kinda resurrecting an old thread here, with an update: I did get the Heritage certificate for the car, and found that it was originally signal red with a tan interior. So the plan became to nix the black interior it has and go back to original. Since the original post, the car now has a completed frame and running gear (frame cleaned, stripped, primed and painted, re-built front suspension, new rear springs, urethane bushings through out, re-built engine, transmission and rear axle, new shocks all around, new u-joints, all new brakes and lines). The body has been stripped of all paint, including removal of the original undercoat from the wheel wells. Rusted areas have been addressed, and we're on to finish body work on the way towards prime and paint. There was a LOT of paint on the car, thickness could likely have been measured with a yardstick. Looks like it went from red to white to blue to red to red again, with coats of primer in between.
I've been looking to find paint codes for the original paint, and have learned a lot from previous posts here on the forums. Question now is which type of paint to go with, urethane or two-stage. Plan on a trip to the paint store in a couple days to pick their brains.
TomMull
I'm not an expert but I do my own paint. I personally don't like the look of a two stage, base coat /clear coat, paint on cars from the 50s and 60s. The look is quite different and not right to me. I use a high quality two part urethane or acrylic (paint plus hardener) on anything that was not clear coated originally.
Tom
ckeithjordan
My 1957 TR3 was delivered in Signal Red. The PO did a frame-off restoration in 1987, repainting the car in Signal Red, matching to the original color, using Ditzler/PPG Acrylic Lacquer finish. When I had my car re-sprayed last February (2020), my body-shop guy matched it to a current GM Red (name unknown) but "AZKO Code" 407f5. I'm happy with the color, and I think it represents the original Signal Red quite well. The original mixes/codes don't mean much for today's paints.
TomMull
Signal red, Standard Triumph 32, is one of the easy ones. Most sources can use the ST32 code. Not as easy with some of the other colors. I can provide DULUX ICI formula if needed.
Tom
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
