TR5/TR250 Water pump housing removal advice
MadRiver
Bronze
Howdy all! It's been a long time since my last post. I hope everyone is well. I sprung a coolant leak between the block and the housing that the water pump mounts on. I guess 54 years was as far as the gasket was able to go. I've replaced the water pump once several years ago, but I've never had occasion to remove the housing. Before jumping in, I would greatly appreciate any words of wisdom or caution! Thanks!
B.
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
K TR4/4A Water pump and water pump housing bolts..... Triumph 3
T TR2/3/3A Water Pump Housing Bypass Triumph 11
CinneaghTR TR4/4A TR2-4A Water Pump Housing Triumph 7
M TR2/3/3A TR3 water pump housing question. Triumph 4
Tinkerman TR2/3/3A TR3 A Water Pump Housing Pipe Triumph 7
Tinkerman TR2/3/3A TR3 Pipe, Water Pump Housing, Mounts Where? Triumph 15
I water pump and housing removal Triumph 4
G Alloy water pump housing Triumph 5
tr6web Water Pump and Housing Triumph 13
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
T TR2/3/3A Moss uprated water pump Triumph 6
Aussiea40 A40 water pump British Motor Corp 7
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
George Zeck Water Pump ? Spridgets 5
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
D TR2/3/3A TR3 water pump question Triumph 4
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
Got_All_4 TR2/3/3A Water Pump "Here I Go Again" Triumph 61
G Water Pump Failure - Diagnostic Steps? Austin Healey 16
Got_All_4 TR2/3/3A Water pump problem Triumph 7
Gordon_Dedrick TR2/3/3A TR3 Water pump replacement Triumph 5
C Healey BN6 water pump and overheating problems Austin Healey 11
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
histerical Water Pump Spridgets 1
D TR4/4A water pump mystery hole Triumph 6
B TR2/3/3A end of me water pump thread Triumph 2
B TR2/3/3A Replacement or rebuild kit for water pump Triumph 11
B TR2/3/3A Water pump color Triumph 4
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
