Water Pump Installation
nevets
I am about to install my rebuilt water pump. According to the rebuilder (Michael Salter), if the mating surfaces are perfectly clean, sealant is not required. I see on a previous thread that some folks recommend using Permatex Aviation Sealant. I would hate to put everything back together only to discover a leaky interface. Just wondering what experiences others have had. Thanks!
You'll be using a gasket, right (I hope Michael wouldn't recommend not using one)? I've installed pumps both ways, with and without sealant, but I typically install using a light coat of Aviation Form-A-Gasket; It sets to a flexible glaze and, in many cases it makes the gasket easier to remove (sometimes intact). I wouldn't use an RTV/silicone sealant here, and definitely not one with 'adhesive' in the label.
Keoke
I Will go along with BOB on the water pump installation Nevets.
nevets
nevets
Thanks for the replies. Yes, I will be using a gasket. Michael Salter included one with the rebuilt pump.
Healey Nut
Hylomar is your friend ….the blue stuff .
Keoke
steveg
More than one way to skin a cat...I've glued the gasket to the water pump with GaskaCinch with Hylomar between the gasket and block. I've also used Hylomar on the thermostat gaskets and the tank sender gasket without any problems. Having said that, I like Aviation Form A Gasket #300.
If gluing, always glue the gasket to the movable part.
I had a bad experience with Permatex Right Stuff - practically had to jackhammer to get it apart.
Keoke
Steve had a bad experience with Permatex Right Stuff - practically had to jackhammer to get it apart.:
Yeah :
That's why we telling him to go blue.
My engine builder used it instead of a gasket on my BJ8's pan; said he didn't expect it would ever be removed. No sooner had I installed the engine than I clanged the pan on a high driveway; tried to weld in situ, made a mess. Took me days to get the pan off; had to saw it off with a serrated kitchen knife (broke one blade into the pan). My elbow hurt for months, I thought I'd permanently damaged it. Fortunately, I found a used pan on eBay that was in better shape than most I've seen, but was $300 (and I was glad to get it).
Did lots of internet searches on the 'right' stuff; found one photo where someone had used it on an SBC intake manifold. They hoisted the engine by carburettor studs and it hung in mid-air. My elbow is starting to hurt again just thinking about it.
nevets
nevets
I got the aviation sealant and will be installing the water pump later this week. Fingers crossed, no issues. Gotta get it back on the road to enjoy some sweet fall driving. Best time of the year for touring the countryside.
JPSmit water pump installation Spridgets 6
T TR6 TR6 water pump installation - use gasket sealer Triumph 7
jerrybny Water Pump Installation Question Triumph 5
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
T TR2/3/3A Moss uprated water pump Triumph 6
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
George Zeck Water Pump ? Spridgets 5
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
D TR2/3/3A TR3 water pump question Triumph 4
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
Got_All_4 TR2/3/3A Water Pump "Here I Go Again" Triumph 61
G Water Pump Failure - Diagnostic Steps? Austin Healey 16
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
Got_All_4 TR2/3/3A Water pump problem Triumph 7
Gordon_Dedrick TR2/3/3A TR3 Water pump replacement Triumph 5
C Healey BN6 water pump and overheating problems Austin Healey 11
K TR4/4A Water pump and water pump housing bolts..... Triumph 3
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
histerical Water Pump Spridgets 1
D TR4/4A water pump mystery hole Triumph 6
T TR2/3/3A Water Pump Housing Bypass Triumph 11
B TR2/3/3A end of me water pump thread Triumph 2
B TR2/3/3A Replacement or rebuild kit for water pump Triumph 11
B TR2/3/3A Water pump color Triumph 4
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
matmire Replacement Water pump issue Spridgets 5
2 TR2/3/3A Classic Gold TR2-4 water pump Triumph 5
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
Got_All_4 TR2/3/3A Water pump dissasembly Triumph 10
L Trouble refitting pulley to new water pump Spridgets 9
