A40 water pump
Aussiea40
Aussiea40
Hi.
Looking for info and a solution to a water pump leak.?
Pump was trashed so had it sleeved to take new bearings and fitted a new kit.
Problem now is it has a leak that defies logic. Thinking it is leaking past carbon seal but the pump surface for that was machined when sleeve was fitted.
Any suggestions or solutions greatly appreciated.
NutmegCT
The weep hole is there to allow lubricant *that's bypassing the seal(s)* to come out, instead of entering the coolant itself.
Weep hole drip usually indicates bad/failing water pump seal(s).
Tom M.
Aussiea40
Aussiea40
New seal kit consisted of spring, carbon seal and carrier, rubber seal behind carbon seal and felt seal up behind bearings.
Wondering if there is any trick to bedding in carbon seal.?
NutmegCT
Wish I could advise on the bedding question - I've never tried that.
If it were mine, and the drip were small and infrequent, I'd probably drive it 100 miles or so, then check to see if it's worse, or if it's closing up by itself.
Sorry I can't be more help.
Tom M.
NutmegCT
Just a thought - check out this water pump discussion. Note the part about "spinning up the pump while dry", to seat the seal.
P Austin A40 Devon windshield. British Motor Corp 2
P Suspension upgrade for a A40 Devon. British Motor Corp 0
A Austin A40 trafficator steering wheel Other British Cars 5
G 1951 Austin A40 British Motor Corp 15
TRopic6 For Sale Austin A30 A35 A40 factory manuals Other British Classifieds 0
78Z Project Austin A40 Somerset ‘Special’ Other British Cars 10
Vikingo Tropical A40 Devon Countryman project Other British Cars 42
C Austin A40 Sport Convertible? Help! Other British Cars 3
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
H Wanted Austin A30, A35, A40 or similar British car in good condition, ready to drive. Other British Classifieds 3
V For Sale 1952 Austin A40 Sports Other British Classifieds 0
J 1951 Austin Devon A40 ID plate Restoration & Tools 3
JPSmit Separate Thread - A40 Somerset hood [Bonnet] ornament Other British Cars 0
S austin a40 somerset chassis swap/upgrade Restoration & Tools 2
B How many of you have or had an Austin A40 Somerset Other British Cars 16
B Austin A40 Somerset build Other British Cars 31
Grannieannie 1954 Austin A40 Somerset Other British Cars 17
C Brakes on Austin A40 Sport Other British Cars 6
JPSmit A40 Parts for free Other British Cars 1
S Austin A40 Somerset convertible Chicago CL Other British Cars 0
a40bob a40 brightwork Other British Cars 1
JPSmit A40 for sale Other British Cars 11
B A40 on Craigslist- Seattle Spridgets 1
aeronca65t Austin A40-mine many years ago Other British Cars 1
S A40 Devon heart transplant Other British Cars 4
78Z Interesting Austin A40 Stuff Other British Cars 5
aeronca65t Austin A40 Other British Cars 5
78Z Austin A40 Convertible Other British Cars 12
gsalt57tr3 Sprite wheel parts compatability for A40 Austin Austin Healey 5
T looking for any info on a 1950 austin A40?? Other British Cars 5
Sherlock Austin A40 Pickup Other British Cars 2
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
D Water Valve Connection Austin Healey 4
T TR2/3/3A Moss uprated water pump Triumph 6
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A Water pumps/head cooling Triumph 22
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
A MGB Stuck water temperature sensor MG 26
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
shadowfever Water temp Spridgets 9
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
