Suspension upgrade for a A40 Devon.
Puddleglum
Hi guys. I've read comments on here and other groups about replacing the A40 front suspension with an MGB front end. Most have suggested it as a good option. Some have said they've done it, but I can't seem to find any pictures or videos showing how it was done or even how the finished project looked. If someone has done it on here, could you post some pictures and/or info of how you went about it? A bolt on front clip seems like a really good option, but looking at it, the MGB clip mounts look to high to just bolt it under the Austin frame.
If someone wants to suggest a better alternative, I'm open to that as well.
S TR4/4A Coil-over suspension upgrade Triumph 4
HealeyPassion New suspension upgrade Austin Healey 9
Moseso TR2/3/3A TR3 -->4 Front suspension upgrade questions Triumph 7
A Revington Rear Suspension Upgrade Feedback Triumph 0
D upgrade front suspension, grommets and sway bar Austin Healey 10
R help with suspension upgrade Triumph 4
M TR2/3/3A Rebuilding suspension Triumph 29
K TR6 Rule of thumb for frt suspension shims Triumph 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
L TR6 MII Suspension Triumph 6
R TR6 Rear suspension droop restraint Triumph 0
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
Healey Nut BT7 Rear Suspension Austin Healey 15
D MGB Rear Suspension Damper Link Arm MG 2
R TR6 Front suspension fulcrum pins Triumph 6
Michael Oritt Evaluating Suspension Components Austin Healey 4
Upland Mark IV front suspension Spridgets 3
JPSmit Suspension question Spridgets 1
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
M TR6 suspension puzzle Triumph 3
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
L 100/6 tuning and suspension ugrades advice Austin Healey 7
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
bugedd Winter Suspension Project Spridgets 7
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
M Creaking rear suspension Austin Healey 13
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
P TR6 tight suspension Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
HighAltitudeTR3 TR2/3/3A Saggy suspension? Triumph 5
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
