actually i have not mounted anything yet. i was trying to plan ahead a little and make sure before i did any mounting. this was the one thing that did not seem to have a clear direction.
well that and i was checking my shocks today for their motion. the PO had purchased what i assume are rebuilt shocks for the car. they both seem to go thru the full motion smoothly with a consistent drag. however the one when i lift it up, will come back down itself. the other stays up. the old shocks that were on the car both stay up. So i wondered about oil in the shock. i pulled the fill plugs on both, plus the old ones and could not see oil in either one. my question is how do you know if you have enough oil in them? should there be oil up to the plug? can't seem to find that in my manual. if you have consistant smooth drag, do you assume you have enough oil? and should the one shock go back down on it's own? keep in mind these shocks are all just sitting on the bench not connected to anything.
Thanks
