TR4/4A Help with deciphering front suspension problem
TRclassic3
I had an "interesting" problem develop with front suspension on early TR4. The issue started when I began jacking the right side of the car. Just as the tire was lifting off the ground (thus weight transfer) there was a very loud BANG. I cannot identify anything that visually appears to be broken, bent misplaced etc. Here is what I do observe (and it may or may not be related to the bang). with the car on stands I can place hands on the tire at 12 and 6, and when I give an up and outward movement on the 6 hand I can see movement in the trunnion, vertical link, ball joint and upper A arm. No movement in lower A arm. Ball joint was new a year ago at which time I also replaced upper A arm bushes. At this point I plan to replace lower A arm bushes, trunnion bushes, seals etc as it seems prudent to do so. That said I would welcome thoughts on this issue and whether there is something I should specifically investigate.
malbaby
"Loud" bang could be associated with the coil spring relocating as the weight is released.
As to the steering components movement, a detailed inspection with the wheel removed is in order. Fulcrum pin failure would be very unlikely.
CJD
From your description it's obvious something is entirely shot or missing. I can't tell from your description if it's one item or the entire suspension, though. If one part is loose or worn out, then everything will have motion. The question is if the motion is with the adjacent parts or apart from the adjacent!?!
NutmegCT
Just a thought ... the bang occurred just after the tire left the ground.
Where was the jack placed? What spot was the jack lifting?
Tom M.
TRclassic3
TRclassic3
Thanks for the response. I wondered as well if the bang was spring relocating. Visual inspection did not show any signs of movement, not that that proves anything. I am beginning to think the bang had nothing to do with the movement I'm detecting.
TRclassic3
TRclassic3
thanks for the response. Close visual inspection does not show anything missing or broken. When I force the movement there is no independent movement between the trunion and the VL, the VL and the ball joint, or the ball joint and the upper arms. Where I see independent movement is the trunion to the lower A arms. Could this be as simple as worn bushes? Right or wrong I was leaning toward the problem being either associated to the trunion or the ball joint.
TRclassic3
TRclassic3
thanks for the response. the jack was placed on the frame about a foot behind the wheel
sp53
Can you drive the car or have you driven the car since detecting the problem. If you have had the car for a while, and driven it and not replaced the low brass bushing for the trunnions, they probably need to be fixed and would probably move. If nothing jumps at you with the loud bag, and you can see nothing, maybe drive it real slow. Or I guess the other front wheel could be loose and moved and made the noise or the whole problem is on the other side, maybe.
TRclassic3
TRclassic3
Quick update. Just studied the movement some more. It doesn’t appear that the trunion pins have play within the bushing but that the trunion is simply rotating a bit and that movement transfers all the way up. What should prevent that movement by hand and without engagement of the spring?
M_Pied_Lourd
I had a coil spring hanging one time on the edge of the spring pocket up in the turret. It made a pretty loud pop once it was relocated to its proper position.
Cheers
Tush
sp53
The spring is caged in the housing and the weight of the car and engine balances the spring into a neutral kind of place. The trunnion and ball joint should turn together on the vertical link. Are you suggesting the vertical link might be broken down in the trunnion?
Steve
CJD
The trunnion should prevent it. The trunnion to vertical link should have very tight tolerances...like .008". If you can see it move, then that is much more than .008". I don't understand your "rotating", as I thought the initial info was movement from up and down direction...are we talking suspension play or steering play...or both?
Also, I am not terribly concerned about the bang unless it reproduces itself. It was most likely something finding it's set. Suspension looseness is a concern, though. Trundles are known to come apart.
STL_Joe Help Deciphering the Commission # Triumph 5
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
