GT6 Help electrical guru needed
Eldwick
My horn, interior light, flasher and radio have stopped working in my Triumph GT6 MKIII. Checked the bottom fuse (Of the 3 in the original fuse box). It was blown. I changed it and it promptly went again. I took my dash out and checked for dodgy wires and changed a connector on the flasher unit. I put another fuse in and it didn't blow but none of the above instruments would still not work. Help.........Any suggestions welcome
NutmegCT
Checked wires, changed flasher connection, new fuse, no short - but devices still not working. I'm thinking a ground strap has come loose.
Do you have a wiring diagram which shows ground wire/straps? I've attached a few which might help. Sorry but I'm not a GT6 owner.
Tom M.
  • GT6 Workshop Manual -page 489 -490.pdf
Platinum
Looks like the top fuse supplies power to all the things not working. Use a 12V test light to see if power is going to that fuse from the brown wire at one end. It should be "hot" with ignition on or off. Then check the other side of the fuse to see if voltage is getting through.
Sarastro
Electrical troubleshooting is just a matter of following the clues and eliminating possibilities until you locate the problem. If you replaced the fuse and the components that are powered by it are not working, you almost certainly are losing power at the block--that's the only place that's common to all of them. It's very likely that something in the connection to the fuse block is loose and shorting somewhere. Depending on the design of the block, it might be on the underside where you can't see it.
Light fixtures are another common location for shorts. There are always spots where wires can fray easily or there is little clearance between parts that must stay separated.
6 Electrical Help Please Spridgets 7
N Electrical Issues Need Help Austin Healey 8
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
H need troubleshooting help with 100-6 fuel?electrical? Austin Healey 9
K Need some help, electrical issue Austin Healey 45
I TR6 Need some electrical help please. Triumph 4
I TR6 Electrical issues - please help. Triumph 5
bash TR6 TR6 electrical help Triumph 11
6 Electrical help please Spridgets 21
I Horn electrical hook up help please Spridgets 15
I Bugeye lighting/electrical help Spridgets 17
DNK Help from electrical Gurus Triumph 4
T 67 Sprite Electrical Problems.... HELP Spridgets 7
T 67 Sprite Electrical Problems.... HELP Austin Healey 1
kyreb1862 Electrical System Problem Need Help ASAP MG 7
Jim_Gruber Fuel or Electrical - Help Needed Spridgets 1
Jim_Gruber Help Needed - Fuel or Electrical Spridgets 16
Lin Electrical Issue - Need help Austin Healey 8
C Electrical Help. Triumph 11
G Spitfire Help with Spitfire electrical problem Triumph 13
1 Help on a bad problem, electrical, fuel? MG 12
curtis Electrical help please Austin Healey 3
M 97 XJR Electrical problems...HELP! Jaguar 10
1 Electrical Help PLEASE!! MG 8
S HELP! with jag electrical Jaguar 2
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
