TR2/3/3A Replace Rubber bushings in front suspension
Redoakboo
I have replaced several ball joints and the pin's on either end of the steering arm. I have several rubber bushings to replace now. I have removed the nut and old bushing, but can't figure out how to get the new ones in? I have tried grease, tapping in with a socket; no luck. I have even thought I should try to freeze them to make them smaller in diameter.
Any ideas?
Dick Vinal 1954 TR-2
Alfred E. Neuman
They're not a super tight fit. Some lube and a large pair of channel-lock pliers should be all the force you need to get them in. Grab the outside of both bushings and squeeze them in into the arm.
TomMull
You might also try squeezing them in with a G-clamp if there is room.
Tom
R
Redoakboo
It's the lower wishbone arm. You have to remove the nut and lower bracket, held on with two more bolts. Moss's diagram shows it as a spacer, but I could tell after removing the old one, it was definitely a rubber bushing.
sp53
So you are talking about the back of lower wishbone? Under the coil spring and spring pan? The bushings that are nylon on a tr3 and rubber on a tr2?
CJD
Bummer. To replace those bushings the lower control arms have to come apart from the spring pan and the trunnion. Essentially the entire front suspension must come apart to access those bushings. As a minimum, the arms must be separated from the spring pan and the trunnion. You MAY be able to accomplish this by placing a jack under the spring and then undoing the 6 bolts holding the pan to the arms...but that will be difficult to say the least. Over time the rubber bushings take a set that is never exactly centered over the pin. So trying to replace only half of a bushing will never work, as you are trying to push a symmetrical bushing in a bore and over a pin which are not.
The original TR2 used a rubber only bushing, but it was changed to a steel/teflon affair midway through the TR3 production. If your bushings are original on a TR2, the inner pin will be heavily pitted. The newer design takes this into account by also providing a steel sleeve to cover the pin, and then teflon bearing surfaces over that. It's a better set-up all around, and I really recommend you switch over while you are there.
R
Redoakboo
I got the rubber bushing installed.
The problem was the threaded shaft was not centered and it was against the top of the arm. I put a pry bar under the end of the arm and kept hitting it until the shaft was centered. At that point , with a little grease, it tapped right in.
Dick Thanks for all the suggestions
T TR4/4A tr4 steering column-replace rubber with u-joints? Triumph 9
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
V MGB Replace late intake manifold angled breather with early model straight? MG 1
W replace rigid master cylinder lines with flex. Spridgets 2
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
B A plan to replace BE floor pans Spridgets 0
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
R TR2/3/3A Replace wiring harness in steering column Triumph 61
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
J TR2/3/3A replace brake and fuel lines? Triumph 4
J TR2/3/3A Replace rusty sills? Triumph 10
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
JPSmit replace shocks in pairs? Spridgets 7
JPSmit When do you replace things? Restoration & Tools 22
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
AUSMHLY When to replace spark plugs Austin Healey 1
drooartz MGB What to replace when engine is out MG 10
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
TRMark TR4/4A Replace Water Curtain Triumph 5
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
S Replace original suspension for shocks? Austin Healey 2
J Replace the outside skin on a cargo trailer??? Restoration & Tools 0
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
7 How to replace door windows on a 77 MG Midget Spridgets 6
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
S Replace seal and dust cap BJ8 steering box. Austin Healey 23
gbtr6 TR6 TR 6 Head Studs, replace? Triumph 3
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
B Radiator - repair or replace? Pics attached Austin Healey 20
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
mailbox General Tech Fix, replace or rewire? Triumph 8
Kleykamp TR2/3/3A '61 TR3 Horns repair vs replace Triumph 15
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
britlover proper tire size to replace 5.90-15? Austin Healey 16
Rob Glasgow Replace clutch disk? Austin Healey 8
S TR4/4A Replace or rebuild heater control valve? Triumph 5
1 MGB Time to replace my top,,experienced recommendations welcome MG 10
R TR6 steering column removal bushing replace Triumph 2
