replace rigid master cylinder lines with flex.
WacoJohn
1960 Bugeye, left hand drive (USA) needs rigid hydraulic lines for brakes/clutch replaced with flexible lines. One 10' line from Master cylinder to clutch slave cylinder and the other 10' from Master cylinder to 'junction' which delivers fluid to the wheels. Appears I need 2 each 10' long(?). Need a source for these lines and have found new RIGID ones from an autosupply house here in US (Advanced Auto Supply). BMC obviously installed originals before installing engine. Getting rigids bent 'just right' with engine installed is practically impossible. Flexible lines would cut the labor down 90%. Any leads? I know the flair, thread, and connector is a bit of an 'exotic' British design, but in looking for flexis, don't know the name of the required nomenclature. Been too long since I sourced the rigids. Any tips appreciated in advance .... even if just the connector type.
Desert Rat
If you have a local place that makes hydraulic lines they could make them for you.
I just finished re-plumbing my Bugeye with stainless steel hard lines. Mine is a complete and driving car, it was a long but not a hard job.
The engine isn’t really in the way and there is room enough on the passenger to feed the lines to the clutch slave. The line to the rear brakes I installed from under the car. The most involved part was removing the radiator and steering rack to plumb the left front brake.
Remove your old lines and use them as a template to shape the new lines and reinstall. I do recommend removing the battery when removing and installing the lines that run along the firewall since they tend to flop around. You can get pre-bent steel (or stainless steel) from Classic Tubing or buy a nickel/copper kit from Moss or Bugeye Guy. Bugeye Guy also sells the clutch line to the slave separate which I don’t think Moss sells.
W
WacoJohn
Thank you for the noble reply and I have taken note of your advice. I think I can find what I am looking for which will cut down the labor quite a bit. Thank you again.
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
V MGB Replace late intake manifold angled breather with early model straight? MG 1
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
B A plan to replace BE floor pans Spridgets 0
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
R TR2/3/3A Replace wiring harness in steering column Triumph 61
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
J TR2/3/3A replace brake and fuel lines? Triumph 4
J TR2/3/3A Replace rusty sills? Triumph 10
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
JPSmit replace shocks in pairs? Spridgets 7
JPSmit When do you replace things? Restoration & Tools 22
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
AUSMHLY When to replace spark plugs Austin Healey 1
drooartz MGB What to replace when engine is out MG 10
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
TRMark TR4/4A Replace Water Curtain Triumph 5
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
S Replace original suspension for shocks? Austin Healey 2
J Replace the outside skin on a cargo trailer??? Restoration & Tools 0
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
7 How to replace door windows on a 77 MG Midget Spridgets 6
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
S Replace seal and dust cap BJ8 steering box. Austin Healey 23
gbtr6 TR6 TR 6 Head Studs, replace? Triumph 3
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
B Radiator - repair or replace? Pics attached Austin Healey 20
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
mailbox General Tech Fix, replace or rewire? Triumph 8
Kleykamp TR2/3/3A '61 TR3 Horns repair vs replace Triumph 15
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
britlover proper tire size to replace 5.90-15? Austin Healey 16
Rob Glasgow Replace clutch disk? Austin Healey 8
S TR4/4A Replace or rebuild heater control valve? Triumph 5
1 MGB Time to replace my top,,experienced recommendations welcome MG 10
R TR6 steering column removal bushing replace Triumph 2
S General Tech replace the head bolts Triumph 4
