Front suspension rubber trunnion bearing question
warwick-steve
Hi
I would like to know please what is the typical life of the rubber bearing/bushes. My car was rebuilt in 2010 approx 18000 miles ago.
I have read both that they can last for decades and also that they can break down in 5 years!! What is typical?
My car just had its annual MOT safety check and there were no issues but I would like to have an idea.
Does replacing involve a complete strip down of the suspension?
Thanks
Steve
warwick-steve
warwick-steve
Hi Steve
I was mainly thinking about the upper trunnion.
Being interested in keeping the car in good condition I was searching previous threads on this excellent forum and came across information about the suspension etc and was interested to know why and how to go about changing the bushes which have a limited life. I got the impression that it is best to stay with rubber but that their life can be short.
Thanks for responding
Steve
steveg
The upper trunnion bushes are inexpensive and relatively easy to change. Support the front end by the spring pans so there's no tension on the upper shocks. Grab the tire and move in and out. You'll be able to see any play in the bush. You can also see play in the wheel bearing.
With the car in this position and tire removed, it's easy to remove the fulcrum pins and insert new bushes.
Lots of folks like the offset poly bushes. IMO if you installed these with a little grease on the pin, they'd probably last longer and you could get yourself a little negative camber.
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
B TR2/3/3A Your Opinion of TRF Rubber Bushes for Front Suspension Triumph 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
M TR4/4A Front suspension Triumph 4
I TR6 Broken front suspension bracket Triumph 3
Scotsman TR4/4A Front Suspension Strengthening Kit assembly Triumph 2
mcmillal TR4/4A Front Suspension Re-assembly Triumph 7
K TR2/3/3A Greasing the the Idler lever on front suspension? Triumph 3
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
Popeye TR4/4A TR4A front suspension quesions Triumph 19
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
C TR2/3/3A Question on assembly of front suspension Triumph 3
W TR2/3/3A TR2/3 Front Suspension Upgrades Triumph 13
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
maxwedge5281 front suspension or braking improvement Austin Healey 25
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
M Adjusting Front Suspension Austin Healey 11
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
bugedd Front suspension and oil pan Spridgets 17
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
bugedd Front suspension springs Spridgets 4
M front suspension rebuild parts list Spridgets 22
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
F TR2/3/3A front suspension Triumph 3
