TR2/3/3A Front Suspension upgrades for the 59
mctriumph
Finally getting to the Tr3a to finish it up after too many years. Been on the road for a few ,but the handling was off.
So the fix is tr4a trunnions and upper arms to gain the castor she needs at speed. She has my 5 speed conversion
and a 160hp screamer that red lines at 6500. With the 370 gears it goes into 5th at 130mph (in theory). Wilwoods
slow it down and I am stoked to have her 10/10 finally.
Not sure what a cop might say if he saw those numbers on his radar.......dont wanna know....
Mad Dog
mctriumph
mctriumph
The job is nearly finished ,funny how one side went so much easier than the other. At least it was unnecessary
to drop the spring as I had feared. Once one of the lower arms is slipped out,the trunnion change is quite easy to do.
MD
CJD
Sounds exciting!
Just a reminder that the TR4 suspension will make the car harder to steer at lower speeds. Most also convert to rack and pinion at the same time to help with steering loads.
Hamish Racing
Sounds similar to mine.
i have 4.1 diff and I tr6 gearbox A type od I max out at about 125
It’s the brick shape that’s the issue.
I still have the steering box too (steering links bronze bushed)
But think about adding camber of about 1.5 - 1.75 deg and run the front wheel parallel ie not toe in.
mctriumph
mctriumph
Camber will help in autocross.Our Tr7 racer had -3 deg front and rear(IRS) The front was too easy,just re-drilled
the lower arm holes on the X member.
Test drove the Tr3 yesterday took it up to 90 (regular traffic speed these days) BIG improvement to say the least!!
I should think that anyone doing the front of a tr3 would make this swap . All those tr4a's were not wrong.
Mad Dog
CJD
I've cruised my TR2 at 110...rock stable. The early suspension will work if set up right. Very few are set up right!?!
mctriumph
mctriumph
The issue many cars have is that ,60 years on, the little wounds of time have added up.
My 59 had suffered a curb hit in the dim past. This had left it with a -.5 deg reading on the rt ft Might have been caught
when the frame was done but sadly I did not detect this slight issue when it might have been easily handled.
This drove poorly to say the least. Not wanting to tear it down and pull the rt suspension tower
back foreward 3mm to gain the .5 deg back, I did the next best thing adding the Tr4a bits and settling
for a cross castor of .5 deg which on all cars is good for most uses.
For track use I would suggest this upgrade as a safety mod. We all like safety !!
Mad dog
Jim_Stevens
I’ve got a RevingtonTR front end, including Rack & Pinion. Good upgrade!
mctriumph
mctriumph
Wilwoods too? It is shocking how much less they weigh when compared to the iron units.Stopping
better is a huge plus,but unsprung weight is nice to lose.
I just could not bring myself to use the stock units on the 59, needs the extra stopping /handling.
Mad dog
mctriumph
mctriumph
The one issue I hit was the imprecise diameter of the tr4 rotor that must be used, ,just a little too big.
which wont hurt the standard unit but the Wilwood is less forgiving I guess.
Mad dog
W TR2/3/3A TR2/3 Front Suspension Upgrades Triumph 13
K TR2/3/3A TR3 alloy wheels and Front suspension upgrades Triumph 14
EMGEBE MGB MGB Front suspension upgrades????? MG 6
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
M TR4/4A Front suspension Triumph 4
I TR6 Broken front suspension bracket Triumph 3
Scotsman TR4/4A Front Suspension Strengthening Kit assembly Triumph 2
mcmillal TR4/4A Front Suspension Re-assembly Triumph 7
K TR2/3/3A Greasing the the Idler lever on front suspension? Triumph 3
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
Popeye TR4/4A TR4A front suspension quesions Triumph 19
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
C TR2/3/3A Question on assembly of front suspension Triumph 3
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
maxwedge5281 front suspension or braking improvement Austin Healey 25
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
M Adjusting Front Suspension Austin Healey 11
B TR2/3/3A Your Opinion of TRF Rubber Bushes for Front Suspension Triumph 6
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
bugedd Front suspension and oil pan Spridgets 17
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
bugedd Front suspension springs Spridgets 4
M front suspension rebuild parts list Spridgets 22
