Moseso
I have been thinking/planning/dreaming about putting the proper TR4 parts on my TR3 to get some caster -- and maybe even go whole-hog, and get the adjustable upper fulcrum kit from Revington to adjust the camber.
I bought a box full of TR4 suspension parts (eBay -- cheap) so I now have the proper upper A-arms.
Question #1: I don't have any TR4 manual or pictures. My assumption has been that the A-arms go on in such a way that the vertical link leans forward, i.e. straighter arm on the front, arm with more offset on the rear. The picture on the Revington site (below) looks like it's the other way around. Which is correct?
Question #2: I will need new trunions. There are two types: fixed pin and bolt-on. Are they interchangeable? Do I need different lower arms to work with either set? Is there any real advantage to the later, bolt-on style?
