Revington Rear Suspension Upgrade Feedback
alansimon
Member
Hi,
Has anyone installed the Revington rear shock-in-coil and anti-roll bar upgrades on their TR6, and, if so, what was the results of the installation? For example, are you happy with the upgrades, did they cause problems, do the short stroke AVO (?) shocks perform well, etc. My son and I are doing a frame-off restoration at Her Majesty's Auto Service and, with the body off, this is a good time to consider the upgrade, although it seems expensive. Any feedback is appreciated.
alansimon
K TR2/3/3A Revington's Rear Spring Locators? Triumph 1
K TR2/3/3A Revington's Rear Spring Location Kit? Triumph 9
mt10flyer TR2/3/3A Revington Roll Bar Triumph 12
K TR2/3/3A Revington alternator heat shield. Triumph 0
T TR6 The price of a Revington TR6 body...whoa Triumph 31
J Revington coilovers with goodparts swaybar Triumph 7
YankeeTR Revington TR Hinges..Are they worth the $$$? Triumph 2
martx-5 Anyone Buy From Revington TR Triumph 7
martx-5 Revington TR Triumph 4
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
