TR2/3/3A Rear leaf spring brass and Delrin bushings ?
CJD
On a street car rubber lasts longer and improves ride quality. On the track, hard bushings control suspension movement and improve handling. So, it's really a choice of how you want to use the car.
sp53
The nylon bushings in the front make a noticeable difference moving the wheel from a stop. At first I did not like nylon bushings, but after i drove for a while I changed my mind and they are a good improve.
Steve
Sarastro
No experience with these in TRs, but it is a big issue in the early Porsche community. Rubber bushings work by bending, but the delrin ones must slide, in a joint that is not designed for that. The result has been wear and loud squeaking--enough to drive the user nuts, and a noticeable difference in the ride. Greasing them helps, but not for long. Dunno if this is an issue in TRs, but after listening to many negative reviews, I've never been interested in installing them, in any car.
I return to the old aerospace industry saying: "better" is the enemy of "good enough."
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
H rear leaf spring to chassis bushing Austin Healey 11
DornTRoriginal TR2/3/3A Rear Axle & Leaf Spring Installation Questions Triumph 3
R Rear Leaf Spring Removal Triumph 10
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
K TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade Triumph 14
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
Tabcon Rear leaf spring bush size? Triumph 21
tahoe healey iron bushing removal rear leaf spring Austin Healey 6
N Rear leaf spring brackets Austin Healey 9
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
8 Rear leaf spring Triumph 3
F new rear leaf spring disapointment... Triumph 9
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
Keith_M Bugeye rear leaf springs Spridgets 19
K TR2/3/3A New Moss Rear Leaf Springs Triumph 7
K TR2/3/3A Moss rear leaf springs? Triumph 19
Jeepster BJ8 rear leaf springs Austin Healey 2
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
P BJ8 phase 2 rear leaf springs Austin Healey 2
D Replacing rear leaf springs ? Triumph 6
bugedd Rear leaf install Spridgets 7
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
tahoe healey re-arching rear leaf springs Austin Healey 27
Johnny AH 3000 BN7 rear leaf springs modifications. Austin Healey 4
B rear leaf springs Spridgets 14
prb51 Rear Traction Bars for our Leaf springs Triumph 0
malice Rear leaf swap. Triumph 8
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
AUSMHLY Rear leaf springs Austin Healey 6
Michael Oritt BN1 rear leaf springs Austin Healey 4
S Rear Leaf Springs Austin Healey 30
bighly Replacing rear leaf springs Austin Healey 10
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
