WTB - rear leaf spring, late model Sprite / Midget
lewmac
I need one good or a matched pair of rear leaf springs for a Mk3 or 4 Sprite / Mk2 or 3 Midget to correct a bad case of Bachelor's lean on my Sebring fastback donor Mk4 Sprite. Car must have bottomed out many times as the rubber bumper metal pad is dented ! Preferably located anywhere in the US - Midwest good, Illinois better, Chicago will pick up !
Thanks
Lew
SaxMan
I have one leaf spring off a '69 Sprite Mark IV. It was a left side spring. When it came off the car, the car was riding level. The right side spring snapped two leaves, so I replaced both springs. Mechanic said the undamaged spring was still good. PM me. I can send you pics. I'm located in Maryland.
nomad
Lew, the Mk2 midget's and Mk3 sprites had a 5 leaf spring while subsequent models had a 6 leaf spring. I've rebuilt several sets of spridget and MGB springs by tearing them down and replacing the polyethylene strips with moly filled poly carbonate that I source from Mc Master Carr. The worn strips are responsible for most of the sag but not all. You can re-arch the springs by taking the leaf's to a hydraulic press but the re-arch usually doesn't last. I've just bought a new spring from Moss to try and alleviate the 'bachelor lean' on my Datsun engined Midget but haven't tried to fit it yet. Seems like it has a lot of arch and is pretty stiff so we will see if that work's. Others have said that the new springs are not very good quality and will begin to sag very soon so I'm not overly hopeful.
Kurt
Morris
I have a theory on bachelor lean... I think it may be cause by the sway bar... or at least aggravated by the sway bar. I originally flipped my springs left to right and the car still leaned to the driver's side. On my car, the sway bar was slightly twisted so that the drivers side would ride lower. I flipped the sway bar over, and my lean is now no longer noticeable.
L
lewmac
Thanks Saxman, but I was able to buy a set from another seller via the Sprite Forum, $40 for the pair, so hopefully I am good to go. If there is a further problem, I may come back to you, as it was the left / driver's side that had the sag.
Interesting theory on the sway bar below..... the sway bar mounts on this car were damaged when I stripped it down, so maybe that was the problem, but seems like a lot of force would be needed to twist the car and depress the rear spring.
Cheers
Lew
L
lewmac
Interesting. The sway bar mounts on this car were damaged - bent - when I stripped it down and with just a rolling chassis the sag was not obvious. As I said above, seems like significant force would be needed to twist the frame and cause a sag. Maybe possible, as yoiu had seen.
Thanks for your comments.
Cheers
Lew
SaxMan
Cheers
Lew
No worries, Lew! It probably would have cost at least that much to ship just one spring to you.
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
RobSelina WTB - 1/2 eliptic rear springs, stock or lowered. Spridgets 4
S TR2/3/3A WTB a tr2 original grill Triumph 0
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
5 WTB: BJ7 Squab Austin Healey 13
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
shadowfever Wanted WTB Spridget seats. Spridgets Classified 0
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
bravenrace WTB - TVR 2500M TVR 0
oldbagpipe Wanted WTB Mayflower parts Triumph Classifieds 2
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
P Wanted WTB Restorable TR4 Triumph Classifieds 7
J Wanted WTB TR 3-4 Generator pedestal Triumph Classifieds 3
R Wanted WTB TR-3A front bumper brackets [pr] Triumph Classifieds 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
R Wanted WTB Big Healey Austin Healey Classifieds 3
red57 Wanted WTB Early Austin Healey Horns Austin Healey Classifieds 1
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
G Wanted WTB TR3 Hood Hardware Triumph Classifieds 0
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
anarchy99 Wanted WTB: 64-66 sprite hood in decent shape. Spridgets Classified 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
L Wanted WTB: Bugeye tonneau cover with roll bar cutouts Spridgets Classified 0
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
J Wanted WTB: TR3a top and Tonneau Triumph Classifieds 2
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
R Wanted WTB Spitfire race/auto cross car Triumph Classifieds 1
A Wanted WTB Generator pulley & fan Austin Healey Classifieds 2
E Wanted WTB BT7 top frame Austin Healey Classifieds 3
Tr3aguy Wanted Wanted: WTB Triumph Classifieds 5
Zitch Wanted WTB - One good wire wheel for Spare [15x4.5] Triumph Classifieds 1
Zitch Wanted WTB - wooden Steering wheel Horn button holder [Missouri, USA] Triumph Classifieds 1
I Wanted WTB - Delaney Gallay heater Other British Classifieds 0
Zitch Wanted WTB - TR4/5 Surrey top Backlight. Triumph Classifieds 11
F Wanted wtb a 69 Triumph TR6,rustfree,for resto or nice or anything inbetween Triumph Classifieds 0
SASSAMON TR2/3/3A WTB Pulley and Fan for TRactor Dynamo Triumph 3
Zitch General TR WTB - Triumph AM radio. Triumph 11
maxwedge5281 wtb ubolt plate for big healey Austin Healey 7
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
Editor_Reid WTB Bugeye Dash Knob Set Spridgets 13
B TR6 WTB: Side marker socket 1971 TR6 Triumph 2
