Thank you for reaching out! I have located a motor - I should have updated this thread, sorry shot that!
If you have one, it can be identified by the serial number stamped on the cover plate, plus confirmed with the wiring configuration. The single speed motor has two(?) spade connectors plus one of the motor housing screws is marked for a ground connection. The the two speed has three signal wires plus a ground wire coming out of the motor.
Two speed motors are rare and worth a fair bit, so it might be worth checking!
