wtb ubolt plate for big healey
maxwedge5281
when replacing the rear springs on my 63 bj7 i noticed that i had a non-stock ubolt plate on both sides. i would like to replace with stock healey plates. or, if not, does anyone know what the stock plate ubolt hole size and location of the holes might be> thanks for any help. maxwedge5281@charter.net
Keoke
The stock plates tend to bend,perhaps the PO made a set out of stronger metal.???
maxwedge5281
maxwedge5281
if someone has a loose plate to measure i could buy a heavy duty, stronger plate off ebay or elsewhere. they plates on my car had larger holes and were spread too far apart. and also had a traction bar receiver.
steveg
You could buy them new from Moss or probably used from British Car Specialists, Healey Surgeons or Mike Salter (michael.salter at gmail dot com). See item #11 on the 'Rear Suspension BN1 to early BJ8' page.
The earlier style are perhaps stronger than the laters. Just measured mine at 3/16" steel. The Moss repros may be wimpier, their u-bolts certainly bend more easily than the OEMs.
maxwedge5281
maxwedge5281
i went ahead and determined the bolt hole spacing and called warrior products to see it they have a similar plate or just send me a couple of blanks and i can drill myself. they make heavy duty ubolt plates for lots of enthusiasts especially off road! awaiting their callback....
maxwedge5281
maxwedge5281
warrior products is going to make up a plate to my specifications for the cost of one side from one of the forum suppliers. it wont be original but it will be heavy dauty and US made.
HealeyRick
Might be a good time to think about some traction control if you're planning on any hard launches. Traction bars tend to hang kind of low. I followed this idea: https://www.britishv8.org/articles/easy-traction.htm I haven't engaged in any smoky burnouts, so can't attest to how effective it is, but it was an easy mod and hasn't affected the handling at all.
maxwedge5281
maxwedge5281
that seems like an easy way to improve traction under hard launches. and, it does not hang low. the ubolt plates that were on the car had provisions for traction bars that i removed several months ago.
S TR2/3/3A WTB a tr2 original grill Triumph 0
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
5 WTB: BJ7 Squab Austin Healey 13
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
shadowfever Wanted WTB Spridget seats. Spridgets Classified 0
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
bravenrace WTB - TVR 2500M TVR 0
oldbagpipe Wanted WTB Mayflower parts Triumph Classifieds 2
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
P Wanted WTB Restorable TR4 Triumph Classifieds 7
J Wanted WTB TR 3-4 Generator pedestal Triumph Classifieds 3
R Wanted WTB TR-3A front bumper brackets [pr] Triumph Classifieds 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
R Wanted WTB Big Healey Austin Healey Classifieds 3
red57 Wanted WTB Early Austin Healey Horns Austin Healey Classifieds 1
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
G Wanted WTB TR3 Hood Hardware Triumph Classifieds 0
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
anarchy99 Wanted WTB: 64-66 sprite hood in decent shape. Spridgets Classified 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
L Wanted WTB: Bugeye tonneau cover with roll bar cutouts Spridgets Classified 0
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
J Wanted WTB: TR3a top and Tonneau Triumph Classifieds 2
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
R Wanted WTB Spitfire race/auto cross car Triumph Classifieds 1
A Wanted WTB Generator pulley & fan Austin Healey Classifieds 2
E Wanted WTB BT7 top frame Austin Healey Classifieds 3
Tr3aguy Wanted Wanted: WTB Triumph Classifieds 5
Zitch Wanted WTB - One good wire wheel for Spare [15x4.5] Triumph Classifieds 1
Zitch Wanted WTB - wooden Steering wheel Horn button holder [Missouri, USA] Triumph Classifieds 1
I Wanted WTB - Delaney Gallay heater Other British Classifieds 0
Zitch Wanted WTB - TR4/5 Surrey top Backlight. Triumph Classifieds 11
F Wanted wtb a 69 Triumph TR6,rustfree,for resto or nice or anything inbetween Triumph Classifieds 0
SASSAMON TR2/3/3A WTB Pulley and Fan for TRactor Dynamo Triumph 3
Zitch General TR WTB - Triumph AM radio. Triumph 11
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
Editor_Reid WTB Bugeye Dash Knob Set Spridgets 13
B TR6 WTB: Side marker socket 1971 TR6 Triumph 2
maxwedge5281 wtb front drums for steel wheels Austin Healey 1
