TR2/3/3A Rear Axle & Leaf Spring Installation Questions
DornTRoriginal
First query is; I am putting the rear axle onto the frame and I'm wondering how, or if, there is a way to make sure the axle is set parallel on the frame? Do I assume that since the u-bolts are on the spring w/ bolt in the center, spring on the front attachment etc. everything is fine?
Second question, the bolt on the center of the right side spring is short, might have been broken off at some point in time (attached is a picture before I took it off the frame) so there’s no way to attach a nyloc nut to it? Is this something I should try to correct by installing a new, longer bolt, or is it safe to assume the four nuts on the u-bolts sufficient to hold everything together? Thanks for the help!
Dorn
The center bolt is a locating stud. It will not get a nut. If you put the axel back as it came off the frame it should be centered.
By the way I will be at Morgan,s Machine shop's car show in Walnut Creek on the 15th. Call me for more info. They took off 7 lbs from the flywheel.
That's a reasonable assumption. The round head of that bolt through the spring should engage with a hole in the axle, providing positive location within 1/16" or so. It will also make it difficult to make any changes to the alignment. If you really want to check, my suggestion would be to assemble the car and then take it to an alignment shop for a "4 wheel" alignment.
The only nut on the center bolt is the small plain nut that fits inside the bottom plate (and appears to be in place in your photo). If it is broken off too short for the small plain nut, then it's probably worth replacing. It's not so important during operation, but it will make spring R&R much easier since it holds the spring leaves together while the U-bolts are loose.
On many cars, the center bolt looks shorter on the passenger side, because the spring is thicker. The factory added some spacer plates to the top of the spring, to make the car sit lower on the passenger side (and hence more nearly level with only a driver in the car) but did not increase the length of the center bolt. That started at TS26904 according to the SPC; and ISTR was discontinued later (maybe only for TR3B).
Great help everyone! I got it back together yesterday and it looks like everything is lined up correctly. I found that the best way to install the spring was to assemble the u-bolts with the front side of the spring on the frame, onto the pin that is attached to the frame which I smeared anti seez goop onto, install the rubber bushings on the real "shackle pins" and bracket then I sliped on the "shackle plate" with pins onto the frame bracket. I had the body off the frame so access was fairly easy. Anyway a good day in that I got it back together and I feel like it is going in the right direction again! Yea!
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R BJ7 Rear Axle Maintenance Austin Healey 5
A Rear Axle Oil Seal Austin Healey 4
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
B How often should you change the rear rear axle oil Austin Healey 9
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
T TR2/3/3A Rear Axle Vent Triumph 12
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
B TR2/3/3A Checking oil in rear axle Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
K TR2/3/3A Rear axle hub removal? Triumph 8
catfood BN1 Rear Axle drain plug. Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
Don_R TR2/3/3A Rear Axle bearings Triumph 3
bugedd Rear axle bump stop Spridgets 7
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
GTP1960 TR2/3/3A replacing rear axle buffer? Triumph 6
