    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR2/3/3A Rear Axle Bearing Grease
mastaphixa
Bronze
My searches have yielded many posts about many subjects related to the outer bearings on the rear axles, but I can't seem to find what the correct grease is for this bearing. Having removed my axles I observe what appears to be black moly type grease in the bearings. Am I correct in cleaning as much of that out as I can and then repacking the bearing with high temp bearing grease (the red stuff)?
Regards,
Steve Baker
Sarastro
I'd think that any good wheel bearing grease should be OK. I look for a lube that is specifically rated for wheel bearings; it should say that on the package. It's probably more important to service them regularly than to use any particular brand of grease.
Madflyer
If you are talking about the TR 3 that is a solid axle housing and is lubed by the oil in the diff what you cleaned out was old cooked oil. The fill hole of the diff. is above the level of axle tube so oil run to bearings. Others correct me if I am wrong. I have never did more than change diff oil you may need to clean axle tube if the car sat for a long time at any point in it's life. Madflyer
Madflyer
So would the grease be general use grease or wheel bearing grease and do you fill bearing half way so seal does not blow out at temp. I know all good questions to pass on. Madflyer
Snowkilts
It's just the same grease you use for the front suspension. The lube chart says "5 strokes" every 5000 miles. If you put too much in it doesn't blow the seal but it does get out and get into the rear brakes.
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
H rear axle bearing numbers Austin Healey 8
J Sealed rear axle bearing? Austin Healey 9
DornTRoriginal TR2/3/3A Rear Axle Bearing[s] repair vs. replacement Triumph 10
J MGA MGA rear axle bearing nut size MG 0
J Rear Axel/Bearing & Axle Seal.\ BJ8 . Austin Healey 5
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
dklawson Spitfire Spitfire - Rear Hub Bearing & Axle Assembly Steps? Triumph 17
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R BJ7 Rear Axle Maintenance Austin Healey 5
A Rear Axle Oil Seal Austin Healey 4
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
B How often should you change the rear rear axle oil Austin Healey 9
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
T TR2/3/3A Rear Axle Vent Triumph 12
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
B TR2/3/3A Checking oil in rear axle Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
K TR2/3/3A Rear axle hub removal? Triumph 8
catfood BN1 Rear Axle drain plug. Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
Don_R TR2/3/3A Rear Axle bearings Triumph 3
