TR2/3/3A Odd question re: rear axle hitting fuel line?
karls59tr
Bronze
Could this happen under certain circumstances....missing rebound rubber,weak springs etc. seeing as how the fuel line runs above the upward arc of the axle?
Geo Hahn
Looking at mine - if the fuel line was mounted correctly that seems very unlikely - more so if the strap is still in place.
Geo Hahn
Oh, there isn't (originally). That is just a length of split fuel line I have slipped on there to prevent the metal line from chafing or rattling against that metal piece.
K TR2/3/3A An odd brake question? Triumph 2
R Odd Bonnet question Spridgets 2
J TR4/4A Odd TR4 transmission question Triumph 10
frankenstang57 Sorta odd 1500 question... Spridgets 4
mikecyc72usa So far so good, but now an odd question Triumph 2
v8mgbal odd structural question Spridgets 6
JPSmit odd question - thermostat Spridgets 16
jcatnite Odd question Spridgets 3
A I have an odd question. Spridgets 18
J another odd question Austin Healey 11
G General MG odd but true! MG 8
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
K TR2/3/3A An odd thought.....vinyl wrap a TR3? Triumph 8
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
S Engine or Tachometer Odd Problem Austin Healey 7
PAUL161 T-Series Odd spark plug encounter! MG 10
Y MGB More things that seem odd.... MG 2
Y MGB An odd (and probable long-shot) request... MG 5
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A T-Series Arkansas MG Odd Lifter Wear MG 12
sparkydave Odd discovery, but still ran OK Spridgets 1
Rut TR6 Odd wheel Triumph 4
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
CJD TR2/3/3A Odd Commission number Triumph 16
steveg Odd problem but it got me home! Austin Healey 9
H TR2/3/3A Odd Speedometer Behavior Triumph 3
J TR4/4A Odd Commission Number Triumph 16
D odd photo Jaguar 6
K TR2/3/3A An odd 56TR3 Commision Number? Triumph 8
R Odd Wiring Failures Austin Healey 14
MisterB MGB New Guy- Looking at Early MGB-Odd one MG 5
AN5Sprite Source For Odd BSW Tap Needed Restoration & Tools 9
K TR2/3/3A Odd looking modified TR3 on Craigslist...saint luis obismo Triumph 24
DrEntropy This tops my "odd cars spotted" personal best Spotted 1
K TR2/3/3A Odd Clutch Failure...Clutch crosshaft bushing goes for a walk! Triumph 6
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
J TR2/3/3A Need an odd part for a TR3 Triumph 4
M TR2/3/3A Tring to find odd TR3 parts again Triumph 24
T photo - odd request Triumph 5
TRclassic3 TR2/3/3A Odd TR3A suspension issue Triumph 11
D Odd pair today Spotted 17
A Ignition rotor recommendations - odd failure Austin Healey 11
texas_bugeye Odd rear suspension Spridgets 8
JPSmit Odd week for odd cars Other Cars 34
BoneIdle Odd squealing in 4th gear MG 2
Sherlock A rather odd truck/motorhome Other Cars 0
B Spitfire odd noise from Spitfire rear Triumph 5
JPSmit odd screen in Mozilla FORUM Navigation Questions 5
Got_All_4 TR2/3/3A TR3A odd windshield studs needed Triumph 4
