Odd discovery, but still ran OK
sparkydave
Was noticing that the Midget was being a bit more temperamental this season than usual when starting cold. Despite the Zenith-Stromberg's quirky reputation, I had mine so it usually started OK, but lately it would start and slowly sputter out, like the choke was pulling off too quickly. Still, once it stayed running long enough and warmed up a bit, it drove fine. After a couple of outings with the wife, discovered the thermostat gasket had let go and was leaking. Put a new one in, and while I was working on it, noticed the vacuum line to the distributor advance had fallen off. :eek: Well shoot, vacuum leaks are never good! Put it back on, and it's starting easier. Strange that despite that, it seemed to have no noticeable effect on driving. And yes, the vacuum advance works, I checked that out.
JPSmit
Jeff Schlemmer from Advance Distributors told me to disconnect the vacuum. He also said that some (some/all?) of the 1500's actually had vacuum retard because of the emissions. I can't recall if mine did only because it was a California car or if all did.
G General MG odd but true! MG 8
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
K TR2/3/3A An odd thought.....vinyl wrap a TR3? Triumph 8
K TR2/3/3A An odd brake question? Triumph 2
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
S Engine or Tachometer Odd Problem Austin Healey 7
PAUL161 T-Series Odd spark plug encounter! MG 10
Y MGB More things that seem odd.... MG 2
Y MGB An odd (and probable long-shot) request... MG 5
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A T-Series Arkansas MG Odd Lifter Wear MG 12
Rut TR6 Odd wheel Triumph 4
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
CJD TR2/3/3A Odd Commission number Triumph 16
steveg Odd problem but it got me home! Austin Healey 9
H TR2/3/3A Odd Speedometer Behavior Triumph 3
J TR4/4A Odd Commission Number Triumph 16
D odd photo Jaguar 6
K TR2/3/3A An odd 56TR3 Commision Number? Triumph 8
R Odd Wiring Failures Austin Healey 14
MisterB MGB New Guy- Looking at Early MGB-Odd one MG 5
AN5Sprite Source For Odd BSW Tap Needed Restoration & Tools 9
R Odd Bonnet question Spridgets 2
K TR2/3/3A Odd looking modified TR3 on Craigslist...saint luis obismo Triumph 24
DrEntropy This tops my "odd cars spotted" personal best Spotted 1
K TR2/3/3A Odd Clutch Failure...Clutch crosshaft bushing goes for a walk! Triumph 6
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
J TR4/4A Odd TR4 transmission question Triumph 10
J TR2/3/3A Need an odd part for a TR3 Triumph 4
M TR2/3/3A Tring to find odd TR3 parts again Triumph 24
T photo - odd request Triumph 5
frankenstang57 Sorta odd 1500 question... Spridgets 4
TRclassic3 TR2/3/3A Odd TR3A suspension issue Triumph 11
D Odd pair today Spotted 17
A Ignition rotor recommendations - odd failure Austin Healey 11
texas_bugeye Odd rear suspension Spridgets 8
JPSmit Odd week for odd cars Other Cars 34
BoneIdle Odd squealing in 4th gear MG 2
Sherlock A rather odd truck/motorhome Other Cars 0
B Spitfire odd noise from Spitfire rear Triumph 5
mikecyc72usa So far so good, but now an odd question Triumph 2
JPSmit odd screen in Mozilla FORUM Navigation Questions 5
Got_All_4 TR2/3/3A TR3A odd windshield studs needed Triumph 4
jvandyke odd noise from the rear [of the car] Spridgets 8
R Odd problem Spridgets 3
swift6 Odd Triumph Logo... Triumph 14
jhorton3 Odd Piece In Spring Spridgets 8
v8mgbal odd structural question Spridgets 6
