TR2/3/3A Odd Clutch Failure...Clutch crosshaft bushing goes for a walk!
karls59tr
Bronze
The clutch stopped working last summer and I just got around to pulling the gearbox to check out why the shaft would only move an inch either way. I figured the notorious taper pin had broken but years ago I had done the 3/8 bolt fix so I thought the shaft may have actually broke! It turned out that one of the crosshaft bushings had come loose and worked it's way out of the housing and along the shaft. This caused just enough play (along with a worn release bearing) that when the clutch was depressed the release bearing sleeve slipped off the input shaft and jammed so could not return. There was a lot of grease on the shaft ends so I may have been overzealous with grease....maybe even forced the bushing out with grease??? Anyone heard of this? I have a spare shaft that is in good shape...old shaft has significant wear. One of the holes in the bellhousing where the bushing sits is somewhat wallowed out on the inner side from the shaft banging against it. I wonder if I built up that area with Kwik Steel or an epoxy mix and then fitted a new bushing I could solve that problem? Was there a post somewhere on using two bushings on each side instead of one? On a positive note the clutch disc and pressure plate are still in great shape. Any ideas or comments?
TR3driver
Great Pumpkin - R.I.P
I wouldn't trust epoxy with a repair like that. Find a machinist that can ream the hole back to round and fit an oversize bushing (or bush it back to the original diameter).
Seriously doubt you forced the bushing out with grease as it is open at both ends and should be a very tight fit. I'm guessing instead that someone damaged the hole installing the bushing (or a previous one).
Too much pressure on that small area to use epoxy for building up surface. Maybe some to hold the bushing in place. A machine shop can easily drill it out a bit and fab a bushing for it. Might as well do both sides while your there.
Marv
TR4nut
Richard Good sells a nifty kit that lets you install roller bearings - might be overkill but it does look nice.
TR4nut
Richard Good is owner of Goodparts - mainly TR6 performance oriented. Here's a link to his kit:
https://www.goodparts.com/shop/index.php?productID=390
Pricey and potential overkill but it shows an alternative to those pressed in bushes.
ps. if you actually did consider the kit it would be best to contact Richard, since this kit is set up for 4A-6 clutches, not TR3-4. The needle bearings would work though, so perhaps he would sell just that part of the setup.
TR3driver
Another possibility might be Herman van den Akker's "Hydraulic throw out bearing". Although he normally sells it as part of the 5-speed conversion kit, I believe it will fit and work with the stock early gearbox (double-check with Herman, though). It totally eliminates the shaft (and that darn taper pin).
https://www.hvdaconversions.com/accessories.html
Sarastro Yet another odd clutch problem. Spridgets 5
G General MG odd but true! MG 8
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
K TR2/3/3A An odd thought.....vinyl wrap a TR3? Triumph 8
K TR2/3/3A An odd brake question? Triumph 2
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
S Engine or Tachometer Odd Problem Austin Healey 7
PAUL161 T-Series Odd spark plug encounter! MG 10
Y MGB More things that seem odd.... MG 2
Y MGB An odd (and probable long-shot) request... MG 5
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A T-Series Arkansas MG Odd Lifter Wear MG 12
sparkydave Odd discovery, but still ran OK Spridgets 1
Rut TR6 Odd wheel Triumph 4
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
CJD TR2/3/3A Odd Commission number Triumph 16
steveg Odd problem but it got me home! Austin Healey 9
H TR2/3/3A Odd Speedometer Behavior Triumph 3
J TR4/4A Odd Commission Number Triumph 16
D odd photo Jaguar 6
K TR2/3/3A An odd 56TR3 Commision Number? Triumph 8
R Odd Wiring Failures Austin Healey 14
MisterB MGB New Guy- Looking at Early MGB-Odd one MG 5
AN5Sprite Source For Odd BSW Tap Needed Restoration & Tools 9
R Odd Bonnet question Spridgets 2
K TR2/3/3A Odd looking modified TR3 on Craigslist...saint luis obismo Triumph 24
DrEntropy This tops my "odd cars spotted" personal best Spotted 1
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
J TR4/4A Odd TR4 transmission question Triumph 10
J TR2/3/3A Need an odd part for a TR3 Triumph 4
M TR2/3/3A Tring to find odd TR3 parts again Triumph 24
T photo - odd request Triumph 5
frankenstang57 Sorta odd 1500 question... Spridgets 4
TRclassic3 TR2/3/3A Odd TR3A suspension issue Triumph 11
D Odd pair today Spotted 17
A Ignition rotor recommendations - odd failure Austin Healey 11
texas_bugeye Odd rear suspension Spridgets 8
JPSmit Odd week for odd cars Other Cars 34
BoneIdle Odd squealing in 4th gear MG 2
Sherlock A rather odd truck/motorhome Other Cars 0
B Spitfire odd noise from Spitfire rear Triumph 5
mikecyc72usa So far so good, but now an odd question Triumph 2
JPSmit odd screen in Mozilla FORUM Navigation Questions 5
Got_All_4 TR2/3/3A TR3A odd windshield studs needed Triumph 4
jvandyke odd noise from the rear [of the car] Spridgets 8
R Odd problem Spridgets 3
swift6 Odd Triumph Logo... Triumph 14
jhorton3 Odd Piece In Spring Spridgets 8
