odd photo
  • Thread starter Deleted member 8987
  • Start date
Deleted member 8987
https://www.flickr.com/photos/jagdavey/4782982890/
Claims to be an XKE FHC wreck. Right.
Somebodies abandoned or mid restoration project. No door, glass, and of all things, an earlier-than-1949 Flathead Ford block laying on the pavement in front of it. Oil filler tube from later flathead sticking up of probably a later intake bolted to the block.
Then there is this horrible damage to a poor unsuspecting traffic light:
https://www.flickr.com/photos/24285729@N07/3084854802/in/faves-londonitalian/
Geo Hahn
I had to scroll a couple of pictures forward before I got the point of the hay bales.
Apparently at a car show and the hay was trying to present it as a 'Barn Find'. Right. Every neglected or abandoned project is suddenly declared a Barn Find. A couple of cow pies or road apples would complete the scene nicely.
PAUL161
First pic, not necessary a Jag, but looks like a normal Camden NJ picture with junk all over the place!:highly_amused:
Deleted member 8987
I'm not sure what you're seeing. Those links go to one photo each. You can scroll up and down from there to other photos, but the first one is a S2 FHC with a hay bale, no door or glass...flathead Ford block laying in front of it.
Second is a bit later Jag FHC, black or dark blue, appears to have been drinking, trying to hold itself up with a stoplight pole.
Geo Hahn
Yes, a 2+2 (note the position of the leading edge of the windscreen). Based on the license plates and backgrounds in the photos it appears to be a car show in Fladungen (northeast of Frankfurt).
Deleted member 8987
And the caption that says:
"Fladungen Classics Germany 04/07/10 Jaguar E-type S2 FHC Wreck"
T photo - odd request Triumph 5
G General MG odd but true! MG 8
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
K TR2/3/3A An odd thought.....vinyl wrap a TR3? Triumph 8
K TR2/3/3A An odd brake question? Triumph 2
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
S Engine or Tachometer Odd Problem Austin Healey 7
PAUL161 T-Series Odd spark plug encounter! MG 10
Y MGB More things that seem odd.... MG 2
Y MGB An odd (and probable long-shot) request... MG 5
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A T-Series Arkansas MG Odd Lifter Wear MG 12
sparkydave Odd discovery, but still ran OK Spridgets 1
Rut TR6 Odd wheel Triumph 4
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
CJD TR2/3/3A Odd Commission number Triumph 16
steveg Odd problem but it got me home! Austin Healey 9
H TR2/3/3A Odd Speedometer Behavior Triumph 3
J TR4/4A Odd Commission Number Triumph 16
K TR2/3/3A An odd 56TR3 Commision Number? Triumph 8
R Odd Wiring Failures Austin Healey 14
MisterB MGB New Guy- Looking at Early MGB-Odd one MG 5
AN5Sprite Source For Odd BSW Tap Needed Restoration & Tools 9
R Odd Bonnet question Spridgets 2
K TR2/3/3A Odd looking modified TR3 on Craigslist...saint luis obismo Triumph 24
DrEntropy This tops my "odd cars spotted" personal best Spotted 1
K TR2/3/3A Odd Clutch Failure...Clutch crosshaft bushing goes for a walk! Triumph 6
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
J TR4/4A Odd TR4 transmission question Triumph 10
J TR2/3/3A Need an odd part for a TR3 Triumph 4
M TR2/3/3A Tring to find odd TR3 parts again Triumph 24
frankenstang57 Sorta odd 1500 question... Spridgets 4
TRclassic3 TR2/3/3A Odd TR3A suspension issue Triumph 11
D Odd pair today Spotted 17
A Ignition rotor recommendations - odd failure Austin Healey 11
texas_bugeye Odd rear suspension Spridgets 8
JPSmit Odd week for odd cars Other Cars 34
BoneIdle Odd squealing in 4th gear MG 2
Sherlock A rather odd truck/motorhome Other Cars 0
B Spitfire odd noise from Spitfire rear Triumph 5
mikecyc72usa So far so good, but now an odd question Triumph 2
JPSmit odd screen in Mozilla FORUM Navigation Questions 5
Got_All_4 TR2/3/3A TR3A odd windshield studs needed Triumph 4
jvandyke odd noise from the rear [of the car] Spridgets 8
R Odd problem Spridgets 3
swift6 Odd Triumph Logo... Triumph 14
jhorton3 Odd Piece In Spring Spridgets 8
v8mgbal odd structural question Spridgets 6
